CV-joint rebuilding
I'm looking to rebuild my CV-joints and I pretty much know the ball-bearings will need replacing. Anyone know where to source them? What's the consensus on rebuilding? If the balls need replacing, just punt and buy a new CV's? Hoping to salvage mine, but I let them go way too far before a rebuild.
Thanks in advance. - Jim |
it's a time vs. cost issue -- some think it fun to rebuild them
did you play with mud a lot as a kid? if so, you may love doing this. it is certainly instructive to do it.... there is a thread with images from a VW manual that will be very helpful to you if you can find it. |
I've never seen CV parts [ball bearings, inner piece andouter "cage?" ] for sale as individual parts..
When my CV's went > there were definite groves in the inner piece > ergo replace the entire CV joint. Personally > I would not replace suspect individual pieces of a CV joint > but replace the entire CV as a single unit. >>> some argue that it's best to just replace the entire axle/CV assembly |
You might be able to find a local re builder that will regrind and fit oversize bearings...most larger city's have someone that does it....If you track the car or do any hard driving I would just get new axle assemblies
Thanks for the useful info. This is kind of what I expected. This is for a track car, so I'm going to go ahead and order up some replacement axles. I'll just be more diligent about pulling, cleaning and repacking them on a regular basis.
Thanks! |
This is what you need
http://www.*****************.com/product_p/pp911.332.030.01.htm |
Tsunamiboy,
That is just disrespectful. You should at least post a link to the Pelican Parts site and not another supplier.:confused: |
Jim, I'm using 930 CV's on a 74 and the pin fits the hole fine without drilling.
Jim:
Give me a call. I have all of the answers for you. Including part numbers, best prices, and best approaches. And advice from Mat. |
| All times are GMT -8. The time now is 06:29 PM. |
