Doug Zielke
Guest
Posts: n/a
Post Pedal pressure
I find the feel of my SC's brake pedal very firm, but lacking in bite and sensitivity.
Don't get me wrong; the car stops well, it's just that I find the pedal pressure is higher than I'd like. BTW, the servo *is* working. The pads are (I think) stock OEM.
Any hints as to what I could do to improve this without going to a whole new brake setup?
Doug
'81 SC Coupe (aka: "Blue Bomber")
Canada West Region PCA
members.home.net/zielke/911SC.htm
Old 04-21-2001, 07:32 AM
john walker's workshop
Guest
Posts: n/a
Post
are your hoses fresh? they swell internally and seal off fluid flow as they age. does your servo hold vacuum? pop out the check valve after 5 min. and listen for a swoosh.
Old 04-21-2001, 10:10 AM
Nickshu
Guest
Posts: n/a
Post
One quick way to check if the vacuum servo it working is to pump the brake pedal up with the car off, then start the car with your foot on the pedal. If the pedal drops when the car starts, the vacuum works. Not sure if this checks if it holds pressure, but at least its a start.
Nick.
_ _ __ _ _
Nick Shumaker
1982 911SC Coupe
nickshu@yahoo.com
PCA -- Rocky Mtn. Region
Old 04-21-2001, 11:46 AM
Doug Zielke
Guest
Posts: n/a
Post
Thanks guys....I think the servo is ok, but the hoses are of unknown age (probably on the ancient side). I think I'll start by replacing them. Just replaced the brake fluid and bled the system a couple of months ago, so I know that part is fine.
Doug
Old 04-21-2001, 09:16 PM
