windshield wiper motor gets very hot
When ignition is on car running or not the wiper motor is very, very hot. Need Help!!!!! it is 83 911sc
AutoBahned
- pull the fuses while you wait for other answers!
i did thanks
AutoBahned
it sounds like switch may have shorted and is sending power to the wipers all the time
Do the wipers run? I might spray water on the glass & run a wire directly to the motor to see if it runs then. -could be 2 things wrong -- the lack of lube in the wiper blade shafts has caused them to freeze + short in switch or the motor could have died... |
the wiper motor does work it is getting hot when the wipers are off
AutoBahned
a bad motor?
I just had this happen to me it is more then likely the motor
Tony Proasi 1969S 1957 VW Pickup |
I'm assuming motor gets current direct from the wiper switch, but I could be mistaken; maybe a relay?
If the motor is bad, why does it draw power with the switch OFF? If it's a faulty switch (always ON), then why doesn't the circuit wire overheat and melt; only the motor gets hot? If a relay sends current to the motor, I can imagine the relay sticking closed all the time whether the switch is ON or OFF. The motor would then work all the time unless it decides to die simultaneously (overheat). Dunno without looking closely at the circuit diagram. Sherwood |
What happened on my early car was winding was very tarneshed and would not return to the complete stop so is the motor was still on but not moving...Ill post a picture later of the guts
UnRegistered User
The motor must have a internal switch that breaks when the motor parks the wipers in the proper off position...
Wouldn't the wipers just keep running if that switch was not functioning? Perhaps there is power being applied at two or more of the "speed taps" that supply power to different points of the motor windings for different speed. Pure speculation on my part.... There is a hot wire (on with ign or acc) to the motor for the park function... Do you have a wiring diagram? Could be a mechanical problem where the wipers don't park in the proper position...
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
When I bought mine, the first time I used the wipers, I thought I smelled the standard "hot electrical odor" but they worked fine. I don't normally drive the car in the rain. After a couple of months, I got caught in a downpour, and had to use the wipers, I smelled that "smell" again, and when I pulled under a covered area, I then noticed a wisp of smoke that appeared to be coming from the fresh air grille area. I turned them off . I got it into my shop, and started tearing it down to access the wiper transmission and the motor. I found that the motor was just about totally craped out. I checked the prices for the new motors....wow, that was an eye shocker, not cheap!!! I did luck out though, and found a NEW, still in the box correct motor. Saved some serious $$$$. I made the replacement, then all was well in the kingdom again! If you do need a new motor, shop around!!! They can be found for much less than the parts distributors have them. Good luck!! Tony.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
can some one show a picture of the wires going to the motor so i can see if wires are in the right spot on the motor thanks ( i got it now i see it in the book lol) sorry for the dum question
Huhh??
