-   -   Window Adjustment (http://forums.pelicanparts.com/porsche-911-technical-forum/39531-window-adjustment.html)
red911 03-14-2001 05:11 AM
Window Adjustment
I have recently replaced the Targa Bar Seal on my 83 911. Everything seemed to go ok. The problem I am having now is that the windows want to push out from the top side seals when up. I finished adjusting the passenger side and it stops and fits into the side seal perfectly except for the rear part of the window against the Targa Bar Seal. I have moved the top side seal out as far as it will go. Could the seal be thicker where it goes down the side or is it not seated all the way in the groove?
john walker's workshop 03-14-2001 08:16 AM
sometimes you have to shim the rubber out, if all other adjustments fail.
targa88 04-22-2001 03:32 AM
How do you adjust the window "camber"? In my case it is nice a tight towards the front/horizontal (windshield) but quite a gap at the rear/vertical (rollbar rubber)?
Oliver911 04-22-2001 05:53 AM
I had to screw with those windows, it's a PITA. Unfortunately you have to take off your door panel and figure out what bolts control what movements of the window. I ended up just shimming them with washers to until I got it right.
Dante Oliverio
