-   -   Dead & left stranded by the road (http://forums.pelicanparts.com/porsche-911-technical-forum/395532-dead-left-stranded-road.html)
911mnypt 02-28-2008 10:29 PM
Well, my baby pooped out on me tonight leaving me stranded just 1/4 mile from home. All of a sudden I felt the engine loose power, sputter and felt like it was running on four cylinders. When I made it to the red light it totally died out and would not start. Thank goodness the street light was on a hill so I was able to coast into a secure street where I was promptly met by a fellow Porsche owner offering to help. When I popped the deck lid open the engine smelt funny like it was hot and my fan belt was way loose! Over heated? Once the tow truck dropped me off back at home, out of curiosity I tried to start the car and it fired right up. However, the engine sounded like it was running rough...man I hope I did not screw it up!
http://forums.pelicanparts.com/uploa...1204266356.jpg
http://forums.pelicanparts.com/uploa...1204266498.jpg
http://forums.pelicanparts.com/uploa...1204266552.jpg
RoninLB 02-29-2008 05:23 AM
something similar happened to mine. Original CIS and fuel pump fed as if engine was running on 4 cylinders for over 25 miles in the middle of Texas on I-10. Turned out to be a weak fuel pump.
maybe do a flow test on your fuel pump
jasonlee 02-29-2008 06:12 AM
I would check the fuel pump. When mine went, I experienced very similar symptoms. Although. mine did not start again until the fuel pump replaced. Good luck.
Don Ivey 02-29-2008 06:13 AM
Same thing happened to me, minus the smell. It was a fuel pump gone bad, so replaced the pump and filter, and all is well. Hope that's all you have to do. Good luck,
Don Ivey
'87 Carrera
911mnypt 02-29-2008 06:23 AM
I replaced the fuel pump "re-furbished" about six months ago...hopefully that is my only problem.
porschefool 02-29-2008 11:47 AM
Replace fuel filter, while you're at it...regardless of it's age.
Just solved what I thought was a huge problem by doing that!
Plecostomus 02-29-2008 11:54 AM
Nice car!
SC-targa 02-29-2008 12:04 PM
Check the fuel pump relay.
Also check if the switch in the fuel metering unit is working.
*Remove the airfilter.
*Turn on the ignition
*Push up the disc in the fuel distributor and listen for the fuel pump. If the swtich is shorted, your fuel pump wont work.
Mine shorted intermittently in there and it took me a bit to solve.
Good luck.
Jerry Kroeger
rusnak 02-29-2008 12:36 PM
somewhat OT....how well did it work out to use the rear tow hook? Any damage? Did they use it as an attachement point to winch the car onto the flatbed?
Thanks, just making mental notes "in case of emergency".
Glad you got it home safely.
fumanchu 02-29-2008 12:46 PM
Let me know if you need a spare set of eyes to help diagnose..as we are close neighbors.
Shawn
911mnypt 02-29-2008 04:42 PM
Originally Posted by rusnak (Post 3799974)
somewhat OT....how well did it work out to use the rear tow hook? Any damage? Did they use it as an attachment point to winch the car onto the flatbed?
The rear tow hook worked well...I was a total nervous Nelly watching it go up the ramp! No damage at all to the bumper. The AAA guy really took his time, 45 min, to load the car. He used 4X4 cut at a 45 degree so the car could roll up on it first before going up the ramp...saving my front spoiler.
This weekend I will start figuring out what went wrong...thanks everyone for their input!
Richard
911mnypt 02-29-2008 04:43 PM
Hey Shawn...just sent you a PM
rusnak 02-29-2008 05:43 PM
that tow truck driver has got to receive kudos for that!
I'll remember the 2"x4" trick, especially if I break down close to home. I've had to push my car to my mechanic's house twice, not fun.
the angle on that back tow hook made me cringe a little, but I'm glad it worked out well.
porschenut 02-29-2008 05:49 PM
All of you guys are ignoring the four most important clues that he gave you - the engine smelled funny, was hot, the fan belt was "way loose!" and it fired right up when back at home. You still want to suggest it's the fuel pump?
rusnak 02-29-2008 05:51 PM
umm, not enough air in the tires?
911mnypt 02-29-2008 06:23 PM
Well I have started to dig into the problem...I turned the key over to hear the fuel pump and it sounded like my coffee grinder, not the normal hummmm. I called the place where I purchased it and the tech said that they have had a ton of them come back...So an exchange is in order.
I called Nate @ 9Motorsport (West Sacramento) and bought a Bosch from him...the kicker to this...Nate said since he will be out in Fair Oaks area this weekend that he will deliver to my house. I don't even know this guy...what service!
Yes, I am writing a note to the AAA guys boss giving him kudos for the job well done!
911mnypt 03-02-2008 04:20 PM
Just wanted to finish this thread...I installed the new Bosch fuel pump and the car runs like a champ! I also tightened the fan belt up since it was way loose...
Buckterrier 03-02-2008 05:36 PM
Not trying to be a Dink here, as I'm happy you solved your problem. But is it a case of you getting what you paid for, both times?
911mnypt 03-02-2008 06:27 PM
Mark,
The first fuel pump I purchased was a reman and the company will refund my money "yes, I got what I paid for...Junk". The Bosch I just installed is not a reman...
Take care,
Richard
Buckterrier 03-02-2008 06:39 PM
Originally Posted by 911mnypt (Post 3804020)
Mark,
Take care,
Richard
Thanks Richard, I was just curious. I'll know to stay away from stuff like that.
