David Griswold
Guest
Posts: n/a
Post Turbo Engine...What is this?
What is the item circled on the right side of the engine bay of this RUF Turbo engine (oddly enough, looks like an Andial intercooler).
What are your thoughts on the air box (or lack of) setup?
[This message has been edited by David Griswold (edited 04-21-2001).]
Old 04-21-2001, 01:01 PM
AMG Hammer
Guest
Posts: n/a
Post
It looks like some sort of cover for the ignition units? Maybe a cover for some Electromotive’s. I had a very similar setup when I purchased my car, even the same triangle Edelbrock air filter.
I would have to say the car isn't a real RUF. The intercooler isn't RUF, nor do I see the standard RUF transmission sticker.
Old 04-21-2001, 01:10 PM
Panic Attack
Guest
Posts: n/a
Post
That's the new accessory hot plate for frying eggs on the PCA outings this year. You are supposed to cast your ballot, via e-mail, for "Club Designated Cook". Seems that some of the varsity members are starting to request more rest stops. Each elected official of the new post gets one of these setups on their car.
Old 04-21-2001, 06:23 PM
RarlyL8
Guest
Posts: n/a
Post
I have seen that aftemarket triangle filter used on a couple of 930s. I can only assume that it allows enough air flow for the needs of the enhanced engines it was on. Anyone know for sure?
David - could you email me some info on your single fuel pump set-up for 930 conversions? I'd appreciate it. This is the final issue that I am tackling. Everything else has fallen into place and it looks like the swap may be pulled off some time in June. I am very excited!
Old 04-22-2001, 07:28 AM
Doug Zielke
Guest
Posts: n/a
Post
Has to be the ignition system. There are plug wires coming from the underside, and there is the "lightning bolt" warning sticker on the top. Could be a "flux capacitor", though.
Doug
'81 SC Coupe (aka: "Blue Bomber")
Canada West Region PCA
members.home.net/zielke/911SC.htm
Old 04-22-2001, 07:41 AM
JDaniel
Guest
Posts: n/a
Question
I looked at the auction this pic is taken from. Is that really a RUF car? The wheels are definately not RUF. The hood has a Porsche Badge and a RUF sticker right below it? The rear lid has a "Turbo" emblem and a sticker that says "Twin Plug" underneath. The front 1/4 panels also have the RUF sticker...? I wasn't aware that RUF used stickers in the late 80's.
Dan Tolley
1987 911 Coupe
http://www.cheaterswayside.com/911/gallery.asp?sort=0&userid=294
Old 04-22-2001, 09:33 PM
AMG Hammer
Guest
Posts: n/a
Wink
If it's a real RUF, they removed every RUF part and replaced it. :-) Where is the RUF intercooler, wheels, steering wheel, rear badge, transmission, transmission sticker, RUF gauges... I could go on and on.
The only time RUF used stickers was on the Yellow Bird below the side blinkers.
Old 04-23-2001, 02:31 AM
