Oil Return Tubes Job - 76 911S
Does anyone know if the heat exchangers need to come on a 76 911? It's a toss up from a view down under.
Thanks.
Old 02-28-2008, 04:57 PM
vash's Avatar
rick. i had a 75. i honestly did one side with the heat exchangers on. too much drinking because i cannot for the life of me remember which side is easier. the other side, no way. you could search some of my old threads. i ended up taking off the heat exchangers, and doing all 4 over again. with them out, it is a slam dunk.
poof! gone
Old 02-28-2008, 05:34 PM
Cool man. Thanks for input. I'll be working on the drivers side - smoking like hell. I've got a bunch of projects lined up. This weather is too damned nice for the car to sit in my garage. 70 degrees in Sacramento and the birds are chirping.
Old 02-28-2008, 05:48 PM
angelny911's Avatar
rick i started same project now at stand still if you need to remove exhaust cut the nuts and barrels off with dremol tool i broke 3 studs ,and now having to drill out ez-out in one of my studs .good luck here 30 degrees in NYC
pca 30 year member,1977 porsche turbo body targa
56 vw ragtop oval
01 harley sportster
18 Chevy Colorado diesel
BIG RED Firetruck and assorted v-dub ,porsche parts hoarder..LoL
Old 02-28-2008, 10:14 PM
Hi,
I did my oil return tubes a while back - and I have zero mechanichal ability! It was a learning process for me - I have an 84 cab BTW. Anyway, I just sprayed WD40 on the heat exchanger nuts and then waited a day. Kept spraying WD40 on to reall soak everything. My heat exchangers came off no problem at all - and it sure made everything easier to get to. I had to use the special tool sold by our host. BTW - while I was in there, I discovered that I should replace all those exhaust gaskets. Also, while I had the heat exchangers off, I degreased the bottom of the car - and also cleaned them. They polish up real nice. I recently read a thread about spraying easy off oven cleaner on them - boy had I only thought of this! Lets see what else. Ahhhh - getting those tubes apart is not that easy at all. And you will need a pair of circlip pliers for the circlip. Thats about all I can think of - good luck -
Mike
Old 02-29-2008, 05:30 AM
Thanks for additional comments guys. Might as well clean things up down there while I'm at it. Easy off? I'll give it a try. I'm hesitant about taking off the heat exchangers -- so I'm going to cross my fingers until I'm sure I have to.
Thanks again gents.
Old 02-29-2008, 10:38 AM
Goldfinger
Mattcamp's Avatar
I just did mine on my '84. It was tight but I did not have to remove the exhaust. I'm not sure if you need to for your year car but I read a lot about my year "84" and many said that you needed to take off the exchanger at least on the drivers side......Not true. Post a pic of the underside of your engine if you have one.
1984-Carrera (pewter metallic)
Old 02-29-2008, 11:06 AM
Removing the Heat Exchangers was actually the easiest step. Trust me - its a piece of cake - as long as you spray on that WD40 and let it really soak. And it really really makes things easier to get at!.
Old 02-29-2008, 12:24 PM
