Guest
Posts: n/a
I mounted Kuhmo VictoRacer V700 on my '85 Carrera. 225/50ZR16 on 7x16 Fuchs in front and 245/45ZR16 on 8x16 Fuchs in back. Because they are lower profile they make the car look a bit weird. Rear clearance is fine. Up front I am going to have to roll the fender lips. The left side seems to have less clearance than the right side.
Guest
Posts: n/a
How are they on the street?
I was thinking of getting these too. Where did you get yours? What are you alignment settings? TIA ------------------ Nick Hromyak '85 Carrera 7 & 9 Fuchs Havin' Fun in Sacramento CA |
Guest
Posts: n/a
They remind me alot of the Comp TA R1's I've used before, you know all the pebbles stick to the tires as you're coasting into the driveway. I have not had a chance to really try them yet as I have not rolled the fender lips. They seem really sticky. My alignment is stock except for -1.5 front camber. I got them at tirerack.com.
