Fuel injector sleve removal
Is there an easy way to removeand replace the fuel injector sleves in the intake manifold of a CIS engine? I looked for a thread here and in the engine builders forums with no luck.
Maybe that means I shouldn't change them as part of my engine rebuild, huh?
But, since I'm having the injectors "reconditioned" I thought this would be a low cost supplement to that effort.
Jack
Old 07-28-2005, 05:54 AM
they should pop out pretty easy with maybe a little persuasion. if you need some I have brand new set I will never use again(efi on it way)
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 07-28-2005, 06:12 AM
I would rather be driving
jpnovak's Avatar
Pull the intake runners. Then place a 1/4" socket extension inside. then press out in vice. You could use a hammer to punch them out since you will not car if the old ones are destroyed.
Installation is the reverse. Don't forget the new o-rings on the injector sleeve.
Old 07-28-2005, 07:42 AM
KNS KNS is offline
I went through this a little while ago, they can be a b!tch. Three of my injectors came out with the sleeves and three did not. You may have already noticed but the intake runners have three little "stakes" around each sleeve. The aluminum is staked over the top edge of the sleeve. If the sleeve won't scrape past these stakes on the way out then you have to grind them off. I used a dremel with a small grinding wheel to grind them down. Take a tiny, little rag (soak with oil or somthing) and stuff it down the sleeve to keep metal shavings from getting down the intake. Have patience. If it still does not want to come out, use a bolt to thread down the inside of the sleeve nice and snug and then pull on the bolt. You are going to need new sleeves after all this (they are not too expensive). It takes time. Hopefully someone else will chime in with more advice.
Kurt
Old 07-28-2005, 07:49 AM
Good info guys. I'm learning.
Jack
Old 07-28-2005, 09:21 AM
Also 6 brand new fuel injector sleeves just like the picture. I will never use these again $15 shipped
this from my add in the for sale section if you need new ones
Ben
89 944,85.5 944
914-6werkshop.com
Old 07-28-2005, 09:32 AM
mb911
If these are the same as Pelican part # C-110-886-03, for 74-83 cars I'll take them Do you also have the Sleve O-rings (Pelican #K-701-446-40) ?
Email me at jholgate@bellsouth.net to set up the payment and shipping info.
Sorry Wayne but I already bought several hundred dollars worth of stuff from Pelican and would be lost without your book.
Jack
Old 07-28-2005, 10:15 AM
no o-rings sorry but if you want them let me
Ben
89 944,85.5 944
914-6werkshop.com
Old 07-28-2005, 01:51 PM
Reviving an old thread but i fugured you guys would know.
Iv got a couple loose injector sleves and a couple loose injectors. They dont seem to leak i checked with a propane torch but would it be wize to replace both the injector and sleve o rings or is it normal for them to be loose? Will i need new sleeves because they will likely be destroyed when removing them to replace the o ring? I do have eratic idle so im not really fixing what aint broke just troubleshooting. I need to pull the injectors to check them soon anyway. Should i just pull and fix the loose sleeves and leave the tight ones
Old 03-01-2008, 04:20 PM
Less brakes, more gas!
euro911sc's Avatar
They will likely be unusable after removal. Also, after 20+ yrs they get brittle and break easier. Probably best to replace all + o-rings on sleeves and injectors for a good fix. While you are at it, get all your injectors cleaned.
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 03-01-2008, 05:50 PM
