Bruce Johnston
Guest
Posts: n/a
Post Tire rubs on fender
On my 82 SC I have Pirelle P-700Z 205/55 ZR 16 in the front and 245/45 ZR16 on the rear. Tonight while I was driving, I was taking a sweeping right curve on a on ramp to the freeway when the left tire rubbed on the fender. After I strightened up, I hit a bump in the road and it rubbed again. (I am on a dive rescue team and was on my to a call out, so I was going a little faster than normal) When I got home I noticed cut marks on the outside edge of the tire tread where it has been rubbed or cut in the past. I found a small mark on the right tire but the left side had marks all the way around the tire.
I was told the car had been lowered but is this damage to the tire from being lowered or do I need to check the front end? I will need to get new tires soon but want to fix the problem before I get them. I found a buldge on the underside lip of the left fender which I pushed back. If anyone has any ideas I would appreciate any help.
Old 04-23-2001, 11:16 PM
Bill Verburg
Guest
Posts: n/a
Post
front/rear? rims? many of us have had that combo of tires or larger with no problems. can you post a pic of the bulge?
Old 04-24-2001, 04:11 AM
Kurt B
Guest
Posts: n/a
Post
It's the inner fender lip. You may want to use the baseball bat trick to roll that inner lip up. I did it on my Carrera, and it's none the worse for wear.
If you do a pelican search on "baseball bat" you ought to find a post that explains how this is done. You'll kill that tire if you contine that way though.
Kurt B
'84 Carrera Cab.
carrera_cabriolet@yahoo.com
Old 04-24-2001, 08:52 AM
thabaer
Guest
Posts: n/a
Post
That doesn't sound normal, my '79 euro started life lower than the US cars ( bumper regs ) and was lowered in Germany, the 16x7s with 205/55-16 rubber don't rub on the front.
I haven't looked for a long time but I don't remember the edges of the wheel well having been modified on mine. I put P700s on when they first came out, no problems. I could imagine a tread design with BIG blocks along the edge being a problem, but you might get your camber checked.
Charlie Baer
'79 Euro 911SC
[This message has been edited by thabaer (edited 04-24-2001).]
Old 04-24-2001, 08:53 AM
movin
Guest
Posts: n/a
Post
I thought that 205/55 16 was the max. factory std. size for the front tires. Should be no problem, isn't for my 87.
Old 04-24-2001, 11:21 AM
Clark Griswald
Guest
Posts: n/a
Post
You didn't say what your wheels are. If you have aftermarket, offset may not be right.
My experience is that the stock 205/55/16 in front is a very close fit with littler margin for error. Mess with the offset and you have problems.
Based on your description, rolling the lips should resolve this.
Old 04-24-2001, 11:34 AM
patalive
Guest
Posts: n/a
Talking
And how is Wally World?
Chuck
83SC
Old 04-24-2001, 12:37 PM
FAST FREDDIE
Guest
Posts: n/a
Talking
I POSTED A FEW DAYS AGO ON ALIGNMENT WHERE I HAD STEVE ALARCON @ JOHNSON'S ALIGNMENTFIX THE RIDE HEIGHT ON MY 89 911. THEY RAISED THE FRONT & REAR (TIRE RUB ON REAR) AND CORNER BALANCED & I HAD NEW RUBBER INSTALLED. SOUND LIKE YOU MAY NEED TO DO THE SAME THING.
REGARDS,
FREDDIE
Old 04-24-2001, 12:42 PM
