witch tire size can I use?
I have a 75 911 with narrow body, and am using the current settings: front 195/60/15 , rear 205/60/15. And I have rolled the fender lips.
question: What is the wider settings that i can use with out rubbing the fender? tks for any advice... |
You are probably at the limit for the rear tires. I had 205/60/15s on 6" rims all around on my 1974 narrow body. I just recently upgraded to 6" front and 7" rear 16" Fuchs and still had to use 205s all around even with the rear fenders rolled a wider tire would not fit.
BEFORE http://lta01.photonet.com/imgs/aux6/...469/384850.jpg AFTER http://lta01.photonet.com/imgs/aux6/...418/384850.jpg ------------------ Shakenbake (Chris Baker) 1974 911 Sunroof Coupe |
| All times are GMT -8. The time now is 01:38 AM. |
