82SC
Guest
Posts: n/a
Post I can hear the oilr gurggle by as it goes to the front oil cooler!!!
I have a 1982 911SC...and when my engine is warm (thus thermostat is open) I can hear the oil burrble and gurggle by under the passenger's foot well...
does anyone else hear this...sometimes it is loud...
I thought there was air in the system so I ran the car without the oil cap...but no change...
So is the oil cavitating in the system?
do I have obstructions???
thanks
MJ
Old 04-20-2001, 02:52 AM
jabb
Guest
Posts: n/a
Cool
Look under the car make sure the oil lines
are not pinched.... If they look ok then
the gurguling should be no problem.
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 04-20-2001, 04:27 AM
orbmedia
Guest
Posts: n/a
Post
This is completely normal on a 911 with a front cooler. It even happens on the 993. It can get pretty loud at times.
Old 04-20-2001, 05:59 AM
sms1305
Guest
Posts: n/a
Post
It happens to mine after start up when I park over night on an incline, nose down.
'89 Carrera 4
'62 190 SL
Old 04-20-2001, 09:12 AM
john walker's workshop
Guest
Posts: n/a
Post
it happens to a lot of them after a fram oil filter is installed.
Old 04-20-2001, 09:24 AM
Jim T
Guest
Posts: n/a
Post
I've never heard that in a 911, and my current 911 doesn't do that.
It don't know for sure, but that doesn't strike me as "normal" behavior. I can't see why there should be any air in the lines near the front of the car. It seems it should be a solid flow of oil, which would not make any "gurgling" noise. Esp. on an SC, which has just the trombone loop.
I do hear often hear the oil as it is being dumped back into the tank, but that is a sound from the tank, in the back. But you sound like you are describing something different.
Old 04-20-2001, 09:37 AM
FRED/LI
Guest
Posts: n/a
Post
Interesting comment about the Fram oil filter causing noise. I know for a fact that certain oil filters can be noisy on their own. The rattle made can even mimic tensioner and chain noise. Last year, I used two German made filters sold by Pep Boys and
both rattled. It could be heard from inside the car. Changed to the OEM and no noise.
Old 04-20-2001, 10:01 AM
Superman
Guest
Posts: n/a
Post
I had a Fram on ly 911 once. It gurgled loudly. It was removed in less than thirty miles. I use only Mahle now.
The oil cooler line gurgle happens too, but not as loudly as that Fram filter did.
'83 SC
Old 04-20-2001, 10:23 AM
rcilurso
Guest
Posts: n/a
Post
You should be happy you hear gurgling... my t-stat is stuck and no oil gets to the front cooler and no gurgle ;(
Old 04-20-2001, 10:36 AM
Joeaksa
Guest
Posts: n/a
Post
Your real problem is that the muffler is far too quiet! Rev the motor up a bit higher and listen to the "music" it makes and press on!
JA
Old 04-20-2001, 01:05 PM
82SC
Guest
Posts: n/a
Post
I just did the Heat Exchanger back date so I think the muffler is plently loud...
it doesn't happen all the time, I think it is when the oil is at a certain level, and maybe pulls some air as it is pumped to the front.
Old 04-20-2001, 01:07 PM
Jerry Madderra
Guest
Posts: n/a
Post
Did you look under the car , maybe its your mother in law .
Old 04-20-2001, 05:44 PM
83 sc euro cab
Guest
Posts: n/a
Cool
there's a mouse in your oil line
83 sc euro cab
Old 04-20-2001, 07:25 PM
Charlie Moore
Guest
Posts: n/a
Post
I had a new '82 - it gurgled just as you say your car does. My present '87 doesn't and I don't believe my previous '85 did either. I think it's just a normal deal on an '82.
Charlie Faux '87 Turbo Look
Old 04-24-2001, 02:14 PM
