81SC Lights have gone crazy. Help please.
Hello,
A rock broke my front right turn signal lens and the bulb was not working either. I replaced both front turn signal lenses on my front bumper and replaced the bulbs. I also replaced the bulbs on both parking lights. I discovered the left parking light had corroded badly and I cleaned all the rust off and managed to put a new bulb in there. To be honest, I am not sure if all the other lights were functioning before the switch and the pelican saleman suggested I change them all. So they should be the correct spec bulbs from Pelican. Here are the symptoms. First, the left parking light never comes on. I assume this is from the corrosion. KEYS IN, HEADLIGHTS OFF: R turn signal and R parking light blinks. KEYS IN, HEADLIGHTS ON: R turn signal and R parking light stays on - no blink. KEYS OUT: If you lift up on the turn signal, the R sided lights stay on. But if you push down on the turn signal, the headlights come on. I read and edited this twice to make sure I am telling you what I am experiencing. Can anyone tell me what the problem is. Thank you in advance. James
James 1969 911E Slate Grey 1981 911SC Wine Red 1997 911C4S Ocean Blue |
Fleabit peanut monkey
Search on "turn signal problems" or some term like that.
Here is an example of what you will find. Troubleshooting my turnsignal/parking lamp |
