LinkBack | Thread Tools | Rate Thread |
Guest
Posts: n/a
Ok I have had the alternator in and out of my car several times checking and double checking my work everything is done right and I did take the alternator back to the shop that rebuilt it and he bench tested it right in front of me and it was charging so I reinstalled it and also replaced the regulator started the car up the battery light is on and I put a volt meter on it and its putting out 12 volts while running. The guy at the alternator shop said something is not energizing the alternator...where do I look now I have checked all the fuses and they are ok......any imput would be appreciated..dont want to have to take my baby to the shop.
Guest
Posts: n/a
How about the wiring is it all good, is there a short in any of your wires?
Guest
Posts: n/a
More specifically, the Blue wire ... which supplies ehergizing current to the field coils of the alternator, and needs a ground in order to be lit up! Check both paths, i.e., the one from regulator to alternator, via pin 11 of the 14-pin connector and to the gauge bulb lead from the 14-pin connector ... for a solid ground with the wire disconnected from regulator, alternator, and gauge!
------------------ Warren Hall 1973 911S Targa |
