Red face Thumping popping
sound from my other car. This something that occurred during an adjustment to the fuel mixture from the mechanic. It runs leaner now but on a cold start (on a cold day) the car starts to pop and thump from the engine. I can feel the thumping/popping in my seat. When the car warms up about 5-6 mins it disappears. What is happening!
Old 02-03-2009, 06:06 PM
Sounds like possible backfiring through the intake which is being muffled by the air cleaner. Don't know what kind of car you have but a lean mixture will cause backfire and will typically go away as the car warms up.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 02-03-2009, 06:21 PM
Zeke's Avatar
Time for a new mechanic. Or at least a reversal of what he did ( by he his ownself )
Yes, how about telling us what model/engine!
Old 02-03-2009, 06:25 PM
The cat converter was removed and so was the air pump. This can cause a backfire but how damaging is it?
Old 02-03-2009, 06:55 PM
Zeke's Avatar
Shouldn't be problem if the air injection holes are plugged.
Old 02-04-2009, 08:54 AM
Designer King
Paulporsche's Avatar
If your car has CIS you may find a slight adjustment richer may do it, or you may need to adjust your wur. If you search you will find this is common for CIS engines.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 02-04-2009, 09:14 AM
Slumlord
Porsche_monkey's Avatar
Sounds like a lean start condition. What made the mechanic want to adjust the fuel mixture and how did he assess the results? By ear, fuel pressure, or did he have an O2 sniffer?
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 02-04-2009, 09:18 AM
