TWM Induction
Has anyone here had any experience with there throttle bodies. I was just wondering how much a setup like this would be. It looks like a better way to go then PMO's.
Generally the TWM 's are mated to an aftermarket brain/fi system. For That purpose they are state of the art and highly desireable. Unfortunatly the state of the art is not cheap, and makes the carbura6tor option(PMO?) look cheap.
Complete set-up for 911 electronic fuel management is about $4,500. Expensive, but probably the ultimate, especially for the track.
Randy W |
see http://members.aol.com/rattlsnak/ignfuel1.jpeg You have to have some kind of management system to use them. I went with the crankfire as well. Some issues included erratic idle(not bad though). If you have to go through some kind of tail pipe emission testing,. Forget it. You can never lean them out enough to pass. The end result was awesome though. When tuned right, they scream! Overall, I was very happy with the setup.
| All times are GMT -8. The time now is 03:11 AM. |
