atr911
Guest
Posts: n/a
Post Conclusion: Fan housing and fan repair
Since this has been mentioned in several topics I wanted to create a new one so that I didn't have to go to all the others and post this new information.
For fan housing repairs, you'll need to find someone with a TIG welder. In my case I was charged $17.50 CAD (about $12USD) and they repaired the crack in the housing for me.
They also told me that it was impossible to repair a chip on magnesium with more magnesium (or the fan itself). An idea that I got though was to take an equivilent piece out of the opposite fan blade. That should ballance it fairly well if you don't want to buy another fan.
Hope this helps and again I'm sorry to flood the board with this topic.
Adam Roseneck
1978 911SC 3.0
roseneck@cyberbeach.net
Old 04-26-2001, 09:22 AM
wckrause
Guest
Posts: n/a
Post
Blades on an 11-blade fan do not have an opposite blade.
Any pieces you take out will effect the performance of the fan, and may cause unwanted noise. You might be better off looking for a good used fan.
Bill Krause
'79 911SC Euro
Old 04-26-2001, 09:39 AM
RarlyL8
Guest
Posts: n/a
Post
Adam - I just had the fan from my 930 motor repaired. It had chips and cracks. I don't know how the guy did it but I can find out if needed (it may take some time, he is an Indy mechanic and May is near). The fan now looks brand new, I posted a picture of it some time back when someone asked about painting and powdercoating.
Old 04-26-2001, 09:46 AM
Jdub
Guest
Posts: n/a
Post
Whoa! If what Bill says is correct, then advice for folks to shave fan blades for powdercoating is bad advice.
It is possible to balance a fan. However, you must turn the fan repeatedly and let it fall to rest, ensuring that (use a table for this) it never falls to the same location twice. The trick is to remove the fan and find a useful center holder that permits 100% spin without (much) friction.
Jw
Old 04-26-2001, 10:59 AM
atr911
Guest
Posts: n/a
Post
LOL, Yeah, I figured out that there is no opposite blade on the 11 blade fans. Stupid error on my part.
What a brain fart, sorry.
Adam
1978 911SC 3.0
Old 04-26-2001, 06:49 PM
Early_S_Man
Guest
Posts: n/a
Adam,
Depending on the size of the missing chunk, it should be possible to saw & file a replacement part to be welded back in place (and take care of the balance problem) ... from an old scrap VW crankcase or transaxle housing (most VW shops have dozens laying around in a scrap heap) ... so check around. Since you've already found a welder, do a little leg work, and the fix is at hand!
Warren Hall
1973 911S Targa
Old 04-26-2001, 07:07 PM
