DSM DSM is online now
DSM's Avatar
New Carpet ??
Hello,
Can anyone recommend a good Auto Upholstery shop in Connecticut? Near Hartford would be good!
Does anyone have experience doing their own re-carpet job. I have 1983 911 Cabriolet.
How hard would it be to do myself?
Should I use some kind of dyna mat for sound dampening?
Any advice would be appreciated!
Dante
Old 03-06-2008, 09:33 AM
porsher
aston@ultrasw.c's Avatar
It's the perfect DIY job: not difficult, just time consuming.
Old 03-07-2008, 11:10 AM
jpl500's Avatar
I never did my 911 but did carpet my MGB. Like aston said, not difficult it just takes patience. I used some lightweight insulation on my MGB and it makes a big difference in cabin heat/sound-even in a convertible.
pat
Old 03-07-2008, 11:22 AM
Tired Member
DaddyGlenn's Avatar
Here is a great thread...
Interior project on my 87 911
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 03-07-2008, 11:24 AM
porsher
pat
I didn't change the carpet in my MGB, I just hosed it out and threw in some more sawdust ;-)
Old 03-07-2008, 11:27 AM
Alii&Maui
Jesset100's Avatar
The stitching around the pieces is what so very time consuming. I was going to use the boarder material around each piece but it didn't look right.
I think it cost less then $100.00 for the materials. It would have been less but when I cut the tunnel and back seat pieces I cut them backwards so I had to get more material.
In the second photo you can see the difference between the factory material(floor mat) and the stuff I used.
As far as how hard it is to do, not very, just use your old carpet as templates.
I'd say DIY first
Their was also a side benefit, when I took out the old carpet from the back seat area it was soaking wet.
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 03-07-2008, 12:23 PM
jpl500's Avatar
Old 03-07-2008, 01:35 PM
Wer bremst verliert
JohnJL's Avatar
Appbiz does good kits. You can do it yourself.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 03-08-2008, 02:28 PM
DSM's Avatar
Do they really? I was thinking about buying from them. Its a good deal!
Can you provide pics of fit & finish with one of their kits?
thx much!!!
Old 03-08-2008, 04:00 PM
Wer bremst verliert
JohnJL's Avatar
All my pics are on the other computer, wife is busy with it.
Search on my name and appbiz. Lots of successful projects done here with them.
You can get as detailed as you want. For both of mine I stripped the interior back to steel but your level of energy and susceptability to rust will govern whether you do the same.
I ordered an RS kit for my 83SC which I later used in a 1971. I had no problems. I n my case I glued 3mm closed cell foam to the back of the pieces to get a bit more deadening with less than 1lb weight for the entire car.
Old 03-08-2008, 05:46 PM
Wer bremst verliert
JohnJL's Avatar
Here is a thread with some of my carpet results.
Introducing my second baby...
Old 03-08-2008, 05:51 PM
