82SC fuel line replacement
How do you attach new fuel lines from the fuel pump to the lines that run down the tunnel?? They look like they are heat fixed onto the tunnel lines - what's the solution??
Thanks |
They're crimped on with metal collars, if you can get a small cut off wheel in there you can cut the collars off, remove the old hose, then attach new hoses with metal hose clamps. Here's a thread where I uploaded a picture of what I'm talking about:
http://forums.pelicanparts.com/porsche-911-technical-forum/343977-1982-sc-oil-line-replacement-post3754130.html
- Everything's easier once you get started. - '95 993 C2 '73 911 Targa '88 BMW M3 '84 Mercedes 190e 2.3 16v |
Thank you for the info - not a lot of room in there.
Fuel Lines .....
Black,
Just completed some work on the fuel lines. Contact me at atd911@hotmail.com and will foward some pictures to help you do the job conveniently. This is an easy job as long as you have the correct fittings. Tony |
