-   -   Does '83 SC still need drivetrain upgrades (http://forums.pelicanparts.com/porsche-911-technical-forum/397168-does-83-sc-still-need-drivetrain-upgrades.html)
Plecostomus 03-08-2008 10:51 AM
I had a mechanic tell me that the necessity to replace chain tensioners and headstuds was thoroughly overblown because Porsche made the '83 SC upgrades themselves (930 tensioners, improved studs, etc) Is this true?
Thanks,
K
tcar 03-08-2008 11:17 AM
My mechanic says that until your timing chains start to make noise on the SC, you do not need Carrera tensioners. That can be a couple hundred thousand miles, depending.
Head studs, if they're not loose, don't leak, leave them.
Joe Bob 03-08-2008 11:17 AM
They DID do some upgrades but the 83 still had some issues....
gtihop 03-08-2008 11:24 AM
mine is an 83 with only 75000 miles. Had 3 broken studs and one very weak tensioner. i would say they all have problems in these areas.
Plecostomus 03-08-2008 03:51 PM
Thanks so much guys!
