Fitted main switch and fire extinguisher today
Hi, due to classic insurance I had to fit a main switch and a fire extinguisher to my car. I did so today. I even fitted a voltage-meter next to the switch. As the CD-radio had trouble to overshadow the car's inbuilt noise (loud exhaust anyone) I found I had no further use for it and mounted the switch/voltmeter in its place.
I fitted the fire extinguisher to the existing holes in the compartement for the gear-adjustment/clamps. It fitted nicely!
Ole
Old 03-08-2008, 09:12 AM
3.2 CAB's Avatar
Nice work! Hopefully you won't ever have to use the extinguisher!
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-08-2008, 09:54 AM
burgermeister's Avatar
How do the "main switches" work? Some sort of cable arrangement that actuates a switch at the battery?
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 03-08-2008, 10:04 AM
"farking Porsche hero"
Rich Lambert's Avatar
Looks good. That's where I put my extinguisher.
Rich
'66 911 #303872
'07 Cayman
'17 Macan
'58 Land Rover S2 88"
Old 03-08-2008, 10:44 AM
3.2 CAB's Avatar
Those main cut-off switches actually are inline with a battery cable. It breaks the continuity of the battery cable that it is connected to.
ON- the cable and circuit is complete
OFF- the cable and circuit is open
Newest additions-
others...
Old 03-08-2008, 11:00 AM
Is that switch to keep the car from being stolen?
Silver 1980SC Euro coupe
Old 03-08-2008, 12:15 PM
UnRegistered User
billybek's Avatar
I would guess to stop it from burning if an electrical fault occurs.
Bill K.
Old 03-08-2008, 03:46 PM
Wer bremst verliert
JohnJL's Avatar
Check your connections don't result in the dreaded voltage (or current?) spike that causes some disconnects to burn alternator circuits.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 03-08-2008, 05:55 PM
3.2 CAB's Avatar
One of the "classic car" insurers that I had talked with, said it needed a master battery kill switch and a fire extinguisher. When I asked about the master switch, they told me that it was to cut power in the event of possible car theft. The switch also had to be located outside the cabin of the vehicle, mainly specified in the forward trunk near the battery. They also inquired about a locking "trunk" release handle. I have a master kill switch, that can be reached from the drivers seat when strapped in, it is in my 440-6pack Road Runner, and its battery is located in the trunk, for better weight distribution. The switch is a little different than the plastic type that is shown. It is all metal and is fused. Also there is another master kill switch mounted at the left rear, just behind the bumper. This is for the pit crew in case they need to kill the car while anywhere in the burn-out or staging area.
Newest additions-
others...
Old 03-09-2008, 12:06 PM
now I know where to tell my insurance man to go if he tells me to install a kill switch in my 911
Old 03-09-2008, 12:50 PM
Which kill switch is that? Is it a 3 pole, 6 pole, etc.?
Gone
92 C2
82 Euro SC race car
993 C4S 3.8
84 Euro Carrera
Old 03-09-2008, 01:11 PM
