82SC
Guest
Posts: n/a
Post Guage Lights
Hey...
I know the gauge lights are 12V 2W...but they are dim
I found equivalents in 5W...do you think that is too much for the wiring...nothing in 3 or 4W...
I ordered 2 just to try...any heads up from electricians...
thanks
MJ
Old 04-25-2001, 12:37 PM
campbellcj
Guest
Posts: n/a
Post
You can get them from the local dealer...one of the very few things in these cars that are cheap and in-stock. I got ten or twenty of them recently for a few bucks.
Just with the new bulbs the dash seems noticably brighter. My thirty-year old bulbs were pretty discolored and dusty.
Old 04-25-2001, 12:52 PM
ClayMcguill
Guest
Posts: n/a
Post
New stock bulbs will probably help a lot, but check the guage lamp power harness (blue wire w/yellow stripe, goes to each and every lamp in the guages), and the ground connection on the back of each guage (the brown wire-ANY solid brown wire on a 911/912 is a chassis ground wire), and the stud ground point to the chassis right where the 3 bulkhead connectors pass through the sheetmetal that seperates the trunk from the the passenger area, under the guages. Make sure the connections are tight and clean-no corrosion.
Clay McGuill '66 912, '97 Jeep Cherokee www.geocities.com/the912guy
Old 04-25-2001, 08:50 PM
Desert Man
Guest
Posts: n/a
Post
I went to my local Porsche dealer and he could only reference a 2w OSRAM bulb. Do you have a part number and are we talking about the BA7s base bulb? On my 88 Carrera the lighing for the Speedo and Tach is very dim and I can't seem to find anything stronger than 2w. Also, where did you order the 5w bulbs? Thanks
Old 04-27-2001, 11:31 AM
82SC
Guest
Posts: n/a
Post
the ones I ordered are halogen...don't know if they will be too bright...I will take pics
for your viewing pleasure
topbulb.com
I also ordered O-5007 to see
This is to confirm that we received the following order:
ordering code item name quantity each total
O-64111 OSRAM 2 $7.68 $15.36
subtotal $15.36
Shipping - UPS Ground Delivery 0.00
insurance and handling $5.95
sales tax $0.00
total charge to credit card $21.31
Old 04-27-2001, 12:00 PM
