Paul K's Avatar
Brake disc question
All:
Should I replace my front discs with OEM or go slotted/drilled? The front discs on my '89 3.2 are scored. I am going to have them turned when I put on new pads and brake lines, but if they are too thin to turn I will have to replace them.
Can I put on slotted/drilled discs with the standard caliper/pad setup? Can I do this to the front and leave the rear stock? Will slotted/drilled discs improve anything? (99% street use) Is OEM the only way to go or is there an alternative that is of similar/better quality?
Thanks in advance,
Paul.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 03-08-2008, 09:53 AM
Nine9six's Avatar
Paul,
You may want to do a search on slotted or drilled rotors, as many have posted on the subject.
I recall reading on some cracking of the slotted or was that drilled rotors. I'm sure it depends on your intended use...DE, AX, trackdaze
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 03-08-2008, 10:18 AM
Paul,
My best advice would be to use a premium rotor; either OEM (Ate is better than Zimmerman) or Brembo. I prefer plain rotors on these particular cars but properly slotted ones are OK, too.
Cross-drilled ones do not hold up as well since these smallish rotors were never meant to be drilled (after manufacture) and tend to crack easily.
FWIW, I NEVER, EVER turn rotors since all that does is accelerate their demise. If they are worn, they get replaced.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-08-2008, 10:51 AM
Paul K's Avatar
Thanks Guys.
I'll order new rotors. I did a search and started reading- huge amount of info out there- but I think OEM (ATE) or Brembo will be best for now. I did a search but all I could find was Zimmerman rotors available from our host- am I missing something? Also, do I need to replace front and rears at the same time?
Cheers,
Paul.
'83 SC Coupe SOLD
Old 03-08-2008, 11:32 AM
Nine9six's Avatar
Originally Posted by Paul K View Post
Thanks Guys.
Cheers,
Paul.
No, you can do them separately...Unless the retailer sells them as a set only.
96 993 C2 (Current)
Old 03-08-2008, 05:15 PM
poc533's Avatar
I upgraded to the PowerSlot Cryo rotors last year on my 86 Carrera.
No rust when the car sits (its primarily a track toy), and improved braking performance (15 track days over since I installed)
86 Carrera POC Racecar
07 Cayman S
13 Tacoma TRD Sport
16 VW Sportwagen
Old 03-08-2008, 07:15 PM
I'm a loser, baby.
oregonmon's Avatar
Hey Paul,
I did the project you are about to do last summer. New front discs, front pads, SS lines all around and fresh Ate blue fluid.
I used these front rotors as they were same size but seem to offer a few benefits, besides the good price.
http://www.ate-na.com/generator/www/us/en/ate/ate/themes/20_ate_brake_products/1_rotors_us.html
I used Hawk HPS pads too. They combo seems great. It took a couple weeks for them to really break in but now they are firm and so little dust compared to what was on there that it's amazing.
Give me a call if you want more info.
1979 911 SC
Old 03-08-2008, 09:23 PM
Paul K's Avatar
Ryan:
Thanks for the info- those are the rotors Steve mentioned. I'll give you a call tomorrow.
Cheers,
Paul.
'83 SC Coupe SOLD
Old 03-08-2008, 09:44 PM
I'm a loser, baby.
oregonmon's Avatar
Damn Paul, just compared our post numbers and needless to say I've got start BS'n more!
1979 911 SC
Old 03-08-2008, 10:15 PM
