Tune up sequence???
Here are somethings I'm going to be doing in about a week and wanted to know if this looks like the right order, so everything gets adjusted correctly.
1.) Trans. and oil change (Swepco and Brad Pen) 2.) Check Valves and/or adjustment 3.) Check Timing and/or adjustment 4.) Tune Carbs |
Job Sequence.....
Rich,
Perform the valve adjustment before changing your motor oil. Clean well the mating surfaces of the lower valve covers and seal them good to minimize oil leaks. HTH. Tony |
why wait on the oil change?
easier to do it when you drain the oil
try it some time w/o draining.... |
Job Sequence.....
Tony |
| All times are GMT -8. The time now is 03:32 PM. |
