964 fan in 3.2
Hi,
Has anyone tried fitting a 964 fan to a 3.2? Is it possible? I`d like to go for the side exit and lose the engine blower...
cheers
Alex
Old 04-02-2008, 10:31 AM
I don't understand what you're trying to accomplish? If you're referring to "backdating the heat" (i.e. removing the engine compartment fan), that's doable (on a Carrera) by simply adding a left hand hot air duct (from a 930, etc.).
Gratuitous pics of Carrera heater backdate...
edited: BTW...welcome aboard!
Old 04-02-2008, 10:51 AM
Sleep Deprived and Grumpy
jwernquist's Avatar
He wants to use the cool looking 964 3.6 Fan alternator assembly on his 3.2!
I'm not sure if it works however I somehow remember seeing someone attempt this at some point on the forums, try searching a bit. Someone surly has done it if possible.
JW
jwernquist@wi.rr.com
262.215.6547
Old 04-02-2008, 11:01 AM
AutoBahned
RWebb's Avatar
less noise but less flow
Old 04-02-2008, 11:05 AM
cheers keith, the 964 fins seem to be a different design which helps the movement of air to the cabin....at least i`m sure i have read that somewhere...and seeing as my fan is making a real noise when cold, i thought i might upgrade the whole lot...
Old 04-02-2008, 11:06 AM
Originally Posted by jwernquist View Post
He wants to use the cool looking 964 3.6 Fan alternator assembly on his 3.2! ...
Gotcha! I'm not familiar with the 964s...anyone have a pic?
Old 04-02-2008, 11:07 AM
wow, you guys are quick on the responses!! spot on JW...I,ll keep digging....
Old 04-02-2008, 11:08 AM
The diameter of the fan assembly is larger in diameter; the shroud is also shaped differently and does not have the provision for ducting air to the oil cooler. Also, the intake ports are shaped differently on the shroud...Not a direct swap.
The 3.6 fan pushes less air...the change was made to reduce the noise level of the fan.
If you still want to pursue this let me know as I have all of the parts available.
Old 04-02-2008, 11:12 AM
Friend of Warren
I like the noise of the 3.2 fan. Distinctive from every other 911 engine.
Kurt V
Old 04-02-2008, 11:29 AM
jwernquist's Avatar
You can as Keith said keep your 3.2 fan and backdate the ducts using the eariler kind. and disable your blower in the motor compartment. From what it looks like its not really worth changing the 3.6 fan over to your 3.2 no real purpose other than the cool curved fan look. Keep the 3.2 fan and just backdate the exhaust get some SSIs on there and you will have plenty of heat and plenty of fun!
JW
262.215.6547
Old 04-02-2008, 11:39 AM
thanks for the great comments everyone - think a new set of bearings and back date is the answer....
Old 04-02-2008, 11:41 AM
MIK911's Avatar
That's a double negative in my book. but....
3.6 fan=less noise, less flow, but looks cool.
Mike
'86 911 coupe
'85 BMW 535i
'11 Cayenne
Old 04-02-2008, 04:08 PM
so does a perfect cosmetic RSR conversion of a 912
Old 04-04-2008, 04:13 AM
