SeaDweller
Guest
Posts: n/a
Question Clutch Recommendation?
Any recommendations on what cluch to use in a '78 SC? Factory? Aftermarket? Brands?
Thanks!
Michael
'78 911SC Euro
Old 04-27-2001, 07:43 AM
Mikkel
Guest
Posts: n/a
Post
I think the original Porsche item is made by Sachs. Probably available as OEM most places. Also there's LUK, but I don't know how good they are.
Old 04-27-2001, 08:12 AM
john walker's workshop
Guest
Posts: n/a
Post
stay with the stock SACHS stuff for longevity and ease of function. resurface the flywheel too.
Old 04-27-2001, 08:30 AM
thabaer
Guest
Posts: n/a
Post
You may already have heard this, but avoid the rubber-centered discs.
Charlie Baer
'79 Euro 911SC
Old 04-27-2001, 09:57 AM
Early_S_Man
Guest
Posts: n/a
Sachs Power Kit.
Warren Hall
1973 911S Targa
Old 04-27-2001, 09:24 PM
Stephan Wilkinson
Guest
Posts: n/a
Post
I put a Truman aluminum flywheel and a Sachs, I believe it was, aluminum clutch into the '83 SC that I just finished restoring. I did it with some trepidation, figuring I'd be killing the engine every other time I started from a dead stop, etc., but it turns out to work just like a normal clutch. Haven't killed the engine once yet on a startup, although it revs and stops just like you'd expect a car with a lightweight flywheel to and idles just fine at 700 rpm. Some people say it would die whenever the a/c came on at idle, but I ripped my entire a/c system out anyway.
Stephan
Old 04-28-2001, 04:44 AM
Wayne at Pelican Parts
Guest
Posts: n/a
Post
The stock system is more than fine for street driving...
-Wayne
Old 04-28-2001, 05:54 PM
chuckr
Guest
Posts: n/a
Post
I put a Sachs aluminum clutch on my 83SC.I got the clutch and all the associated parts needed for a good clutch replacement from Pelican.Be sure to get new throw-out bearing and have your flywheel checked or even order a new one and if it is not needed send it back.I ordered everything needed for a clutch job except the flywheel,I thought I could get it re-finished, it was to far gone...my mechanic provided one at his cost (ouch!)
Old 04-29-2001, 07:01 AM
