| Hi |
				Clock Repair
			I'm trying to repair my clock.  It was keeping perfect time then as the weather got colder the clock would stop and then when it warmed up a bit it would run again. Well, now it's gotten to the point where; regardless of hot or cold it doesn't hardly work at all. I have read in some forums that folks have replaced the capacitors and got it working again. Mine don't appear to be burnt but i was going to replace them anyways. Problem: What kind do I buy? They don't seem to have the usual marking. Can anyone give me the specs on these? Thanks in advance.    | ||
|  12-27-2009, 09:06 AM |
| Registered Join Date: May 2009 Location: Lakewood Colorado
			I would call up Albuquerque Speedometer Service.  The man who runs the shop is named Peter and he is a VDO trained technician.  He did my clock and my speedo for me recently for around $120 for both and they look and work great.  He could give you some advice or provide the parts you are looking for.  (505) 242-2449
				__________________ 1969 911T - The "Rat" 1997 A4 Quattro 2.8 (270k) - Black Kaniget - Dead but not forgotten 2010 Jetta TDI Sportwagen - Egg Butt (also Spewing Dragon) 2001 Eurovan Weekender - Bruni | ||
|  12-27-2009, 09:40 AM |
| RETIRED |
			Just a thought....Buy a watch or get a radio with a time function...replace the gauge with something useful, like a head temp/alt gauge....
|  12-27-2009, 10:07 AM |
| AutoBahned |
			my clock has the same symptoms - it at least slows down in the cold, if it doesn't stop entirely I always thought it was the grease congealing in the cold + dirt & crud find out if your clock is Quartz controlled also... | ||
|  12-27-2009, 11:47 AM |
