Flash Not Working ?
Hello everyone SmileWavy
Right i went out for a drive with friends the other day and went to use my lights to flash them and they did not work,but if i pushed the light stalk forward main beam still works :confused: Any ideas could it be a relay :( |
Probably the stalk. You may need to replace the stalk or it could just be loose contacts/wiring inside.
Do a search and you will see tons of stuff. |
Thanks ill have a look over this weekend
Iv just had a nosey at this problem i have and in normal position with the stalk it's on full beam and if i push it forward it goes to normal beam and when i pull back it don't flash.
Also my fog lights have stopped working is this all 1 problem or 2 ? |
| All times are GMT -8. The time now is 03:08 PM. |
