-   -   need help finding cv joint washer (http://forums.pelicanparts.com/porsche-911-technical-forum/397890-need-help-finding-cv-joint-washer.html)
kodioneill 03-12-2008 12:32 PM
1974 4 bolt cv joint. took my axle shafts to a machine shop today. they pressed off the two cv joints and in the process they lost one of the conical backing washers between the shaft and joint. i cannot find a replacement anywhere. can anyone help?
Jadams1 03-12-2008 12:52 PM
McMaster-Carr
http://forums.pelicanparts.com/uploa...1205351555.jpg
RWebb 03-12-2008 01:06 PM
can you post a pic or a diagram of what they lost?
also, this is NOT your problem - it is theirs -- they can replace the whole axle if they can't find the washer...
BlueSideUp 03-12-2008 01:12 PM
He's saying they lost the big washer that goes between the CV joint and the seat on the axle shaft.
Our good buddy Warren can help you out.
http://forums.pelicanparts.com/uploa...1205352744.jpg
He is looking for #9
Original Post
http://forums.pelicanparts.com/showthread.php?s=&threadid=62514&highlight=joint+% 2Aassembly
kodioneill 03-12-2008 01:43 PM
thanks guys i found the washers in the pelican parts diagram. and ordered them.
