-   -   Head Liner, how much to replace? (http://forums.pelicanparts.com/porsche-911-technical-forum/398301-head-liner-how-much-replace.html)
911st 03-14-2008 05:36 PM
I need a new head liner for my 85 11 Carrera w sunroof due to an accident while having the window tint removed. :(
Anyone know the total cost or how many hours a professional shop should charge to replace it.
Are the part as follows? New head liner, rear window seal, front window seal...
My best guess is $300 to have the front & rear windows removed and reinstalled.
$150 for headliner, $100 for window seals and about 5 hours at the uplosery shop.
Thus about $11oo????
Thanks for your help.
Ron.G 03-14-2008 07:23 PM
You also have to remove the rear quarter windows and the door seals. The liner is glued around all the window openings.
I bought the head liner and brought the car to a home based guy and he did it for 150.00
This was part of a restoration so I had all the windows out already and I put them back in. The rear window defroster wiring is a PITA as is the window moldings.
The rear quarter windows are not fun either. The cost of those quarter window seals alone exceed your figure for window seals.
This is a pretty sizable job.
more bad news. Most ordinary glass guys will not even touch a Porsche.
You should try to do as much of the work as possibe to keep cost down. There are alot of great posts on the whole process right here on Pelican.
