PeterTarga's Avatar
Whats wrong with my lock
I have problems with the lock on the drivers side, I have already removed the handle with the cylinder but I can't still turn the knob. And I can not see how the mechanism is working. Does someone have clear pictures of the lock and what could it be ?
Thanks for helping
Peter
Old 03-15-2008, 01:37 AM
Peter,
If the door is open it wont turn, close the door and see if it works while closed. It is a lockout prevention enhancement. It only works this way on the drivers side, the passenger side lock does not have this feature.
Shane
Old 03-15-2008, 01:44 AM
PeterTarga's Avatar
Hi Shane,
Great help, you solved my problem, I knew it I should post my problem earlier here. I have the car more then 4 years and I'm learning still a lot , thanks to this forum and the helping people
Thanks again
Peter
Old 03-15-2008, 02:05 AM
Peter,
I am glad to have helped. Enjoy your day.
Shane
Old 03-15-2008, 02:12 AM
Slantnose Huckleberry
courtc2911's Avatar
Door Lock Problems
I have this exact same problem on my 82. Drivers side door only. Door open or closed, I can not lock the door either with the manual knob or by outside key lock. The knob nor the key will turn at all.
Passenger side door works fine but when I lock it, it automatically unlocks.
Anybody have any insight into this issue?
Thanks,
Court
82 Slantnose
Old 03-27-2008, 06:49 PM
Caliber
1987 911 Cabriolet
Old 03-27-2008, 09:50 PM
Caliber
1987 911 Cabriolet
Old 03-27-2008, 09:57 PM
courtc2911's Avatar
I appreciate the pics of the door inards. I'm still not sure however what my specific problem is with the drivers side door lock not moving.
Can anyone else help?
Thanks.
82 Slantnose
Old 03-28-2008, 10:59 AM
Mike_Lettrich's Avatar
The photos are of the window regulator, not the locking mechanism. The locking mechanism in question is inside the door furthest away from the door hinges. It can't be seen on any of these photos.
Look at where the lock button on the top of the door is. You can follow that down to the pivot, then along a rod that goes behind the vapor barrier. Where that rod terminates is the part that is most likely causing your problem.
Old 03-28-2008, 11:48 AM
PeterTarga's Avatar
courtc2911
I can't help, but did you see this thread:
Door Lock Help
Peter
Old 03-28-2008, 12:04 PM
courtc2911's Avatar
Peter,
Thanks for finding that post. It will help tremendously considering all of the photos.
Court
82 Slantnose
Old 03-28-2008, 12:58 PM
