just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
removing front fenders
I have searched a few different times and not found what I was looking for so I thought I would ask
I am planning on replacing my front fenders and have not found anything covering the removal and replacement procedure.
anybody have any links or advice?
thanks a million
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 12-30-2007, 06:10 AM
steve911's Avatar
I can't give you a complete answer, but be aware that there are two hex head bolts inside the door jamb (5 or 5.5MM - I can't remember) that also have to be removed in addition to the bolts inside the trunk.
Recommend using a ball-head hex wrench to get these out. I'll see if I can find a picture. There was a thread on replacing the cowl seals not too long ago.
Try this:
Removing front fender 78SC what tool??
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 12-30-2007, 06:55 AM
just me
paulgtr's Avatar
thanks
I have that type of wrench so that shouldn't be a problem.
are there only bolts in the trunk that have to be removed?
or are there more inside the wheel well.
and do I need to remove the bumper?
Old 12-30-2007, 07:10 AM
Evolved
Mo_Gearhead's Avatar
There are a series of bolts inside the wheel well (rear, vertical) as well.
Not sure if your bumper will need to come off (I doubt it).
Don't fear the reaper.
Old 12-30-2007, 07:26 AM
group911@aol.co's Avatar
It's usually easier to pull the bumper as well so you can get to the screws that attach the bumper smile to the fenders.
Inside the headlite buckets, there are bolts that hold the fender to a bracket.
In the lf fender, you have to remove the bolts for the washer bottle and pull the expansion tank off as well.
The rocker panels need to come off in order to work the fender away from the body.
The gas filler neck needs to come out and the rubber cup that it goes through needs to come out.
You need to either drop your antenna or pull the wire out of the body.
Probably more but I'll have to think about it.
Thanks,
Bob
group911@aol.com
Old 12-30-2007, 07:41 AM
just me
paulgtr's Avatar
cool
rocker panels are off already. never liked the look of them.
pulling the bumper is not too difficult?
need to do a quick search on that
Old 12-30-2007, 07:46 AM
Slumlord
Porsche_monkey's Avatar
That job is a complete pain in the @ss. The bolts behind the door are covered in a thick goop that has to be removed. Take the wheels off, heat the goop with a heat gun and then cut it away with a knife. The 5 mm bolts at the dash level are also hard to remove, they can be very tight and the ball end hex driver will slip out.
Good luck, I hate removing fenders..
Old 12-30-2007, 07:55 AM
just me
paulgtr's Avatar
oh no!
fortunately I have put aside plenty of time.
what kind of goop?
like a rust sealant?
do I need to re-goop it after wards?
Old 12-30-2007, 07:59 AM
2Utes's Avatar
the goop seems to be factory coating and is not really sticky, just tough. on the right front fender there is one bolt at the top behind the oil lines. you will need to loosen the oil line clamps to get to this bolt. you may need a mirror to locate it.
for the 2 allen bolts just below the windshield, i used a 5mm allen screwdriver tip in a 1/4 inch socket with a universal joint with extensions to get it out. getting it back in is a real pita.
nothing hard, just use patience to avoid creating additional work.
if you pull the bumper, try to record all wire connections, especially the ones inside the turn signal housing to make reinstallation easy.
Jeff
'82SC Pacific Blue
'02 C4S Silver (Gone but fondly remembered)
'11 GTS Amethyst
Old 12-30-2007, 09:33 AM
I agree. Removing fenders are an absolute pain.
Old 12-30-2007, 10:44 AM
Seemed pretty easy to me, and I'm about to do it again--the dreaded Rust Monster.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 12-30-2007, 02:00 PM
just me
paulgtr's Avatar
so is it necessary to melt the goop in the left front fender well?
I plan to take plenty of pictures as I take things apart
that usually simplifies the re installation process
are the wires different colors?
or should I label them as well?
Old 12-30-2007, 08:45 PM
Slumlord
You don't need to melt it, you need to soften it.
Old 12-31-2007, 04:59 AM
I generally don't do anything with the undercoating on the lower 3 or 4 bolts. I just apply decent pressure on the ratchet while attempting to remove the bolts and the ratchet eventually catches the bolt head through the undercoating.
The top bolts on the other hand (top of the fender in the curve) generally require scraping off some undercoating around the bolt head in order to get the socket to fit the bolt. Those bolts are a PIA.
Old 12-31-2007, 05:13 AM
hey Paul
how did you make out?
did you use dum dum or the factory goop between the fenders and tub?
how did the front spoiler install go?
post some pics
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-15-2008, 02:54 PM
just me
paulgtr's Avatar
haven't done the swap yet.
waiting to find a good paint shop out here and get an estimate on painting the car.
once I know when I will get the paint done then I will swap the fenders out.
I have collected all the factory parts to do the job apart from the plastic dog bone spacers for the top of the chin spoiler.
Old 03-15-2008, 07:35 PM
you're the type that could do a paint job.
If they're throwing around big numbers maybe give it a second thought?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-15-2008, 07:58 PM
just me
paulgtr's Avatar
with no garage to work in I think that would be a step too far
I have to work al fresco
Old 03-15-2008, 08:01 PM
dam
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-15-2008, 08:18 PM
just me
paulgtr's Avatar
yup....
so if you know a good paint shop
I am all ears
Old 03-15-2008, 08:20 PM
