3.2 service intervals
Does anyone know what is involved in the 60,000 mile service interval for a carrera 3.2?
I see some cars being sold with this recently being done. Is this just a valve adjustment/fluid change? Thanks |
From the table in my owners manual:
Oil & Filter Valve Clearance V-belt & Polyrib belt replace spark plugs Replace engine air filter Replace fuel filter Replace Oxygen sensor Inspect for leaks Crankcase ventilation system check Intake air hoses inspection Check brake pads, pedal & system (fluid) Clutch adjustment Steering gear, ball joints, tie rod ends Wheel Bearings Drive shafts inspection Lube clutch release lever and spring Transmission for leaks Exhaust system visual inspection Tires Throttle actuator AC system Transmission oil Check fuel system for leaks Parking brake adjustment Headlight Adjustment |
I have also wondered about service intervals for the Carrera.
The major one is supposed to be at 15k, but is there a minor service in between? And does every major service include the same things. I have my original owners' manual but not the book where the dealer would indicate/stamp that the work had been done. Could somebody post a copy of this information? Thanks. |
| All times are GMT -8. The time now is 01:26 PM. |
