-   -   71T Where is the *$%#@ Idiot light sender?? :) (http://forums.pelicanparts.com/porsche-911-technical-forum/399039-71t-where-idiot-light-sender.html)
Sam 69 Gulf 03-18-2008 02:49 PM
Sorry – I know this is an over posted question but after reading all the posts I am still in the dark.
At the back of my engine, but accessible from the bay, is a pressure sender. Is this in the wrong hole or is this the correct location? I guess I could pull the wire and see if the pressure gauge dies when i get home.....
If this is in the right location where is the idiot light sender? Does someone have a nice pic to idiot proof it for me??
Sam
http://forums.pelicanparts.com/uploa...1205880520.jpg
BlueSideUp 03-18-2008 02:55 PM
http://forums.pelicanparts.com/uploa...1205880902.jpg
Gogar 03-18-2008 02:58 PM
Oil pressure sender:
http://forums.pelicanparts.com/uploa...1205881069.gif
Down by the fan and the right-bank chain cover?
porsche930dude 03-18-2008 03:04 PM
Blue side i thought that was the oil temperature? Maby it is on my sc?
rusnak 03-18-2008 03:04 PM
there are 3 sending units, or sensors:
idiot oil pressure light sender: this is the one that you are pointing to, next to the crancase breather tube and the oil cooler thermostat.
oil pressure sensor: located at the rear of the engine near the crank pulley
oil temp sensor: near the pressure sensor.
I'll try to post a picture, but you can also refer to the exploded view parts diagrams locate elsewhere on this website.
http://forums.pelicanparts.com/uploa...1205881487.jpg
BlueSideUp 03-18-2008 03:07 PM
I thought the same thing before I bought my car. The later cars have the oil pressure sender to the passenger's side of the fan. On the early models the temp sender is in the breather cap (you can see it in this pic) and the oil pressure sender goes into the hole behind the green wire in my photo.
http://forums.pelicanparts.com/uploa...1205881673.jpg
Sam 69 Gulf 03-18-2008 03:11 PM
Thank you Rusnak – very helpful.
I currently have a pressure sensor (as in post # 3) in the hole designated for idiot switch in your diagram.
Mind you - when I bought this the plugs were finger tight and the leads on the wrong plugs (#4 & #5) :)
At least I am finding these now and it explains why the idiot light doesn’t work!
Sam
p.s. 4 responses in 10 minutes. I love this forum - I'd hug y'all if you were here for the trouble you have saved me!!! :)
Sam 69 Gulf 03-18-2008 03:14 PM
Uh - oh. hold my last post!
Blue side up - So my pressure sender maybe in the right hole. Where does the idiot light sender go? Where you originally said? (sorry - i didn't see your arrow until now)
Sam 69 Gulf 03-18-2008 03:15 PM
I wonder why previous posts confused me :) Those Germans - playing musical senders!
Gogar 03-18-2008 03:20 PM
IDIOT LIGHT Sender by "Blue Side Up"'s green wire.
PRESSURE SENSOR, like post #3 right near the passenger side of the fan housing and the passenger-side chain cover.
OIL TEMP sensor, by the oil pressure sensor and the passenger-side chain cover.
Blue Side up, I don't think the thing in the Breather cover is the OIL temp sensor, if you read the diagram Rusnak posted. Sam won't find anything like it on his engine.
Sam 69 Gulf 03-18-2008 03:24 PM
My temp sensor is where BSU indicates the idiot sender.
I dont have anything in the breather
I dont have anything near the passenger side of the fan housing.
My head hurts
I will pull the wire from the pressure sensor currently mounted near the breather and see what happens!
rusnak 03-18-2008 03:31 PM
if you have the 71 2.2 liter crankcase, here's the exploded parts diagram.
http://www.pelicanparts.com/PartsLookup/HTML/SubCat/911_USA_70_73_KATALOG.htm#
click "Engine/ crankcase" and you'll go to the parts diagram
here's a head hurter for ya though, part #59 oil pressure sensor is shown in two locations....
on the other hand, the location of the idiot light sensor seems to be resolved
Sam 69 Gulf 03-18-2008 03:41 PM
Still confused. The parts diagram shows my pressure switch correct but I am still no clearer where the idiot switch goes. As I cannot see it I will assume it is not accesible from the engine bay??
Gogar 03-18-2008 03:48 PM
Sam,
Here's my 2.4. Oil temp sensor right at the base of the fan housing/support, that your engine # is stamped on. Just to the right of it, at the base of the cam oil line, the pressure sensor.
Pressure wire is GRN/RED, temp sensor is GRN/BLK.
Sorry about the camera phone pic.
http://forums.pelicanparts.com/uploa...1205884088.jpg
Edit: Of course, like the rest of us, I may be completely wrong if there's some diff between '71 and '72/73. ;)
rusnak 03-18-2008 03:48 PM
the oil pressure switch **should** be the idiot light switch. It is an on/off switch hence the application to the idiot light. it should come on when you turn on the key, and switch off when the engine oil pressurizes.
The pressure senser is the bell shaped sensor, and the temp sensor....is ah, I don't know where it is on your car.
rusnak 03-18-2008 03:50 PM
ok there you go, Gogar shows where the oil temp sensor goes (not idiot light switch).
Pressure sensor right next to it.....idiot light switch then must be on top next to the breather tube fitting.
Sam 69 Gulf 03-18-2008 04:02 PM
:) :) Thank you all very much...buuuuutttt. Nothing so far has represented the combination of current senders, or even available holes, in my car. I will take pics of each existing sender openings and parts and post later.
Meanwhile I wil forget the light and keep an eye on the gauge!!
Thanks again
Sam
rusnak 03-18-2008 04:05 PM
sam
think of the idiot light sending unit as a switch.
The oil pressure as a sensor,
oil temp as a sensor.
pics would help. are we having fun yet?
Sam 69 Gulf 03-18-2008 04:10 PM
Got it. I understand how the switch can have one wire but was confused to see the (variable resistance) pressure switch and temp senders only have one wire too. I assume they must ground through the case? I would have thunk this woud give eroneous results.... (spoken like an ME, not EE - mind you as they used to say in school. You can't spell geek without a EE! :) )
It is a good job I love this car. At times like this it stops me putting am match to it! ;)
RWebb 03-18-2008 04:14 PM
such a simple thing and so complicated...
It gets complicated 'cuz Porsche moved these things to different locations at different times - also there are other oil temp. sensors or switches - e.g. item #40 in the 3.2L diagram above (controls the blower fan maybe). And IIRC, there was some sort of temp. switch on some MFI cars(?)
I -think- they used to have the oil press. sender up on top of the motor. Later, it migrated down to the chain housing area. I don't know if there is any difference in oil pressure between the two locations (does anybody know??) - or if fluctuations are more prominent at one location or the other.
At one time, either Porsche or maybe only VW had a dual pressure can - it had a switch and a sensor in the same big can.
Anyway, be sure to check the wire colors on any sensor looking thing you see.
Gogar 03-18-2008 04:25 PM
Sorry in advance if I'm wrong. I'm only going by my experience on the 2.4. Now you guys really have me wondering too!
Sam 69 Gulf 03-18-2008 05:27 PM
OK, here are my P & T sensors. I verified this is the pressure sensor by pulling the wire and pegging the gauge. (2nd pic is P by Breather)
There is no trace of a p Switch. Based upon earlier posts I am now assuming it is on the back of the cowl?????
does anyone have a 71T and pretty pictures???
http://forums.pelicanparts.com/uploa...1205889960.jpg
http://forums.pelicanparts.com/uploa...1205889984.jpg
odog 03-19-2008 06:53 AM
Sam,
I believe there are (at least) two solutions here.
A) the early sender (OP) near the breather cover was a two pole sender- which would be for your wiring harness- new ones seem elusive
B) convert to the later style arrangement-removing the adaptor near the breather cover, re-formating the right cam oil line/sender block arrangement and extending the harness with a jumper to reach the gauge sender near the fan
Hope this helps
Sam 69 Gulf 03-19-2008 08:27 AM
Solved?
So it appears there may NOT be a location for a separate idiot light switch. That maybe why we cannot find it.
Has anyone seen one of these two pole senders? How many wires? my current harness only has one to this location - surely that cannot work for both instruments??
If they exist, have one wire, and anyone has one - I'll buy it!!!
Trackrash 04-14-2008 06:06 PM
According to the owners manual "the oil pressure warning light (green) (not furnished with optional instrument cluster)"
So if you have the "optional" oil temperature/pressure gauge you don't have a oil pressure warning light.
BTW I didn't realize that for the first 20 years I had my car.
Hope this helps.
Gordon
