-   -   Need Help Locating Window Seal (http://forums.pelicanparts.com/porsche-911-technical-forum/399682-need-help-locating-window-seal.html)
Paulporsche 03-22-2008 12:26 PM
I need to replace the fuzzy lined seals in which the front windows ride. I am having trouble locating what they are. Are they part number 91154290500, Window Guide, or is there a rubber part that slips into it? I am not referring to the squeegee.
Do I want "Window Slot Seal" 901-531-935(6)-20-M20?
This is for a 77 coupe.
If I knew how to post a pic from the parts diagram I would have.
ossiblue 03-22-2008 07:13 PM
Try the catalog search again and type "door window felt" into the search box. I think that is what you are looking for--the part #s end in ----M260.
bluesky 03-22-2008 07:38 PM
The PET Shows three parts but they all end up being the same number:
i) 911-542-905-00 for the top channel
ii) 911-542-905-00 (same as #i) for the front channel
iii) 911-542-905-00 (same as #i & #ii) for the rear channel
when this it plugged into the Pelican, it shows on the link below as #27
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait= N&make=POR&model=911E&section=BDYsl2&page=1&bookma rk=3&part_number=911-542-905-00-M260
Paulporsche 03-22-2008 08:17 PM
Number 27- Coupe Window Channel it is. 911-502-905-00-M260.
Thanks to the 2 blue guys!
