Mitch Leland's Avatar
Heater control cable wires
Howdy,
My heater control wires were stuck so before I fried the heater control module on the console I decided to replace the piano wire cables. The old cables were really OK, so I'm thinking that the grease in the cable housing was just gunk up.
Anyone have any recommendations on how to clean up the interior of the cable housing and what lubricant you would use for the new cables?
Thanks,
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 03-30-2008, 05:14 PM
I think it may be more likely that your heater valves need lube. If you climb under the car and carefully disconnect the control cables at the valves you will be able to determine if the binding is in the cable or the valve.
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 03-30-2008, 05:32 PM
Howard,
No, the heater valves were free... The piano wire was just stuck, I had the console off of the E-brake and was able to finally pivot the bell crank on the side of the E-brake. When I extracted the cables they came out with some tugging, but were sluggish.
I'm thinking I might get some gun cleaner in an aerosol can and squirt down the housing before installing the new cables.
Thanks,
Mitch Leland
Old 03-30-2008, 08:39 PM
AutoBahned
RWebb's Avatar
Swepco makes a cable/chain lube and Pelican carries it -- spray can
Old 03-30-2008, 10:06 PM
3.2 CAB's Avatar
I would first spray a cleaner of your choice down through the cable guides. I have found that after many years, all of the dead, sludge lube has harden and will make it almost impossible for the new cores to slide in them smoothly. When I refurbished my heater control lever cables, I found some stainless steel core material here locally, something like $0.40 a foot. I even made up a new way for the cables to be attached to the levers, the pics are in some of the other threads about this. It sounds like you are on a good start. Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-31-2008, 12:37 AM
fred cook's Avatar
Cool Heater cables.............
When I replaced the wire heater cables on my SC, I took 2 vacuum caps, cut an x slot on the end, packed them with grease and put them on the ends of the cable housings. Now the inside of the housings are protected from road water/trash and the cables get a little "lube job" each time the levers are opened. Just a thought.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 03-31-2008, 04:43 AM
Cab and Cook,
Great information... and I thought I was the only one with this problem. :-)
Thanks,
Mitch Leland
Old 03-31-2008, 07:21 AM
kodioneill's Avatar
i was a porsche mechanic in the 70's. on the 70 era cars we would use a old clutch cable attached to a drill with lots of penatrant and run it in and out of the tube followed up by blowing air through it. i'm not sure if it will work on your year or not but thought i would pass it on.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 03-31-2008, 07:46 AM
Kodinoneill,
Great idea, it sure can't hurt. I've shot brake cleaner fluid into the cable housing from the tunnel end, but I don't think it goes very far down the housing. The rubber tipped air nozzle will blast what ever remaining debris might be left in the housing.
I think I'll use a liquid oil (Tri-Flow or similar product) rather than grease. I think the grease holds more dirt and has more chance of gumming up the cable.
Thanks,
Mitch Leland
Old 03-31-2008, 10:50 AM
Mitch,
You might want to remove the guide sleeves from the car to clean and inspect them. I'd want to make sure that the cables haven't worn a groove into the plastic of the guide sleeves. The cars with auto heat control tend to move the cables back and forth a lot. I've replaced damaged sleeves before...
JR
Old 03-31-2008, 11:40 AM
JD,
Thanks, and I'll check the nylon tubing. It turns out when you run the new cable in the cable housing it catches on the joint between the hard tubing and the nylon tubing and pushes the fitting on the nylon tubing off. It appears that there is no positive connection between the two sleeves? It's just a slip fit...
Mitch Leland
Old 03-31-2008, 01:32 PM
3.2 CAB's Avatar
Porsche Crest Cable Cores
Mitch, I believe that you are correct with that observation, it is just a slip fit.
Here are a couple of pictures of a set of heat levers and new type cable connectors.
Newest additions-
others...
Old 03-31-2008, 08:05 PM
