Guest
Posts: n/a
I would like to know if anyone is aware of the inner workings of the Carrera's airflow meter. To be more specific, I need to know if there is a intake air temp sensor built into the airflow meter and if so, which pins correspond to it? Volkswagen 4 cylinder engines that use Digifant injection have an identical (but smaller) airflow meter and they do incorporate an air temp sensor. I would like to know my intake air temp before and after the intercooler, without having to install an aftermarket sensor setup.
Thanks Mike 86 Carrera t |
Guest
Posts: n/a
It does have an air temp sensor. It is a non-linear NTC thermistor. Pinouts are in Bentley and (I think) Haynes manual.
