-   -   3.2 injectors (http://forums.pelicanparts.com/porsche-911-technical-forum/399753-3-2-injectors.html)
BT911 03-22-2008 06:13 PM
3.2 injectors
hi. i'm removing my injectors from my 3.2 and installing them on an other 3.2 manifold. my question is the seal kit that i got for the injectors don't look like the old one and i'm not quite sure how to install the new kit. has anybody done this? thanks
3.2 CAB 03-22-2008 10:17 PM
I have replaced my o-rings with the replacement sets. There are more parts in the little bag than you will actually be using for the 3.2 injectors. Out of the pack, it is just the two o-rings that are changed out. The little plastic "hats" stay in the bag, not used. You should have two o-rings, one goes on the top, the other on the bottom. Be sure to lube them a little before installing. Hope this helps. Good luck!! Tony.
BT911 03-23-2008 12:18 PM
thanks Tony for the help. that's what i thought as well. thanks
3.2 CAB 03-23-2008 01:21 PM
That's great!! I am glad if I was able to help, Tony.
