300hp 1800lbs is the goal
pksystems's Avatar
OEM Nardi for a '66 912?
I did some searches and most of the Nardi wood steering wheels look to have the momo aftermarket bolt pattern. This wheel does not.... Is this an OEM wheel for a 1966?
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 03-23-2008, 02:43 AM
No - it's an aftrmarket Nardi wheel.
The last Porsche that had (an option) of a Factory-fitted Nardi wheel was the 356A.
Andy
M&W 904 ... now gone
GT-style 356C ... also gone
Old 03-23-2008, 03:09 AM
ttweed's Avatar
While they might look the same, the Nardi bolt pattern is a silly millimeter or two different than the Momo. You have to use an adapter to mount a Nardi wheel to a Momo hub and vice versa. That wheel probably has a Nardi/Personal hub, if there is no adapter ring under it.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 03-23-2008, 08:20 AM
