SC flywheel differences
Anyone know the differences between the early and late SC flywheels?
Pelican shows different p/n's for them... And, anybody know the wt. of the stock SC flywheel? |
yea, i was going to suggest you watch out for the difference in your WTB post.
the early flywheel has a pressed in throwout bearing. the later SC flywheel has one that bolts onto the crank with 3 small allen bolts. lemme see if i can find a photo. |
here is an early FW
http://forums.pelicanparts.com/uploa...1206316503.jpg lemme know if you need a pic of the later one. i have one on my workbench. |
Thanks Vash - yes a pic of the later one would be great. Esp. if you have a closeup of the bearing area difference.
I guess I have another question now -- which one will fit a 3.2L crankshaft?? |
The late model that works with the bolt-in pilot bearing will mate up to a 3.2 crankshaft. That's what I have in my motor.
| All times are GMT -8. The time now is 07:43 PM. |
