-   -   It's alive!!! - the 71E project moves on its own. (http://forums.pelicanparts.com/porsche-911-technical-forum/399941-its-alive-71e-project-moves-its-own.html)
jpnovak 03-23-2008 06:35 PM
Happy Easter everyone.
My weekend started off with some wheel refinishing. Start with some nearly trashed 16x7 fuchs. Combine one bag of playsand and 80 psi. Next stir in 2 hours of cleaning and taping followed by a touch of rattle can finish work and voila!
http://forums.pelicanparts.com/uploa...1206321999.jpg
Now that I have rubber on the E project car it was time to make it move on its own.
I went for a maiden voyage around the block tonight. I fit the new wheels and tires but they will not work. they are too large and are rubbing badly in the rear. I will try a bit more negative camber but I don't think that will solve the problem. I don't want to shave the fender lips but that is an option.
I think the front hubs need to be rebuilt. One of them is groaning. I found two small weeps in the oil lines. I will re-tighten the fittings and that should solve the problem.
Other than those minor things the car ran well. It smoked a lot for the first few minutes. but that is to be expected since it has not been run in 10 months. Once it was warm I ran it up through the gears a few times at redline. Lemessee! 2.7 check, S cam check, MFI check, 7300 rpms check. yep, Fun and quick. This is quite the ride.
Here are a few pictures.
http://forums.pelicanparts.com/uploa...1206321963.jpg
http://forums.pelicanparts.com/uploa...1206321972.jpg
http://forums.pelicanparts.com/uploa...1206321982.jpg
pitargue 03-23-2008 06:53 PM
Nice ride!
Where did you get your bumpers?
boba 03-23-2008 07:11 PM
SWEET. Looking good.
Can't wait to see it in person.
Bob
jpnovak 03-23-2008 07:20 PM
PItargue - the front bumper came with the car and is unknown origin. The rear bumper is a narrow body RS unit from Rennspeed. Oh, and the hood and rear decklid are also from Rennspeed. the stock steel units had suffered too much "heavy hand" syndrome over the years.
Bob, It has been too long coming to get this car back on the road. nothing like taking a rusty beat-up driver and making it look good in its Easter Sunday Best. ;) Come to think of it, it has been exactly one year. I looked at the car and had a handshake deal on Good Friday 2007,
Jack Olsen 03-23-2008 08:01 PM
That looks light.
Larry_Ratcliff 03-23-2008 08:29 PM
I really like what you did with those wheels
4flyboy 03-23-2008 08:48 PM
Sweet Bird Jamie congratulations.
S.
RSBob 03-23-2008 09:37 PM
Really like its super clean look with those gorgeous wheels. Nice work.
RWebb 03-23-2008 10:37 PM
sanitary!
can you post a low angle shot of the front? looks like you have grill installed?
jtf914 03-24-2008 04:12 AM
Congrats Jamie, looks great!
Jim Richards 03-24-2008 05:17 AM
Outstanding work, Jamie! That's a nice looking hotrod. :)
jpnovak 03-24-2008 06:07 AM
Its good to see that you all notice the theme of the build. That is, to build a very clean, sleek car that maximizes the visual impact of the shape of the car with no distractions from trim or other things. I love the color (964 linen gray) and how it works well to establish the whole look and design.
The car corner balanced at 2170#. I managed to shed a few pounds but it was not built to be ultra light weight. It retains all the stock interior and ancillaries.
Randy, Yes, there is a grill. While replacing the rockers I ran AN16 lines inside.
http://forums.pelicanparts.com/uploa...1206362927.jpg
then I mounted the oil cooler.
http://forums.pelicanparts.com/uploa...1206362940.jpg
then I built a duct for it.
http://forums.pelicanparts.com/uploa...1206362947.jpg
Here is the final install.
http://forums.pelicanparts.com/uploa...1206362954.jpg
The bumper has a cutout to match the size of the cooler.
http://forums.pelicanparts.com/uploa...1206363076.jpg
I shaped a section of grill material to match the contour of the bumper so that it would better blend. I think it came out rather nice.
http://forums.pelicanparts.com/uploa...1206363128.jpg
JayG 03-24-2008 06:14 AM
Wow, beautiful build up and I love the way you pulled off the oil cooler. Very classy car.
RWebb 03-24-2008 01:01 PM
Nice - the perfect car for touring the Hill Country...
tcesar888 03-24-2008 02:58 PM
Jamie! Great ride and photos...
Two Questions...
1. ) What did you do to get your wheels like that? I want that bad...
2.) The oil cooler project; did you buy a kit or did you fab that your self? Can you provide and details and specs on DIY?
Thanks so much! Great job!
Tom
'71 911E Coupe 03-24-2008 05:12 PM
Wow, real nice E!!! Any pictures of the engine?
jpnovak 03-24-2008 05:59 PM
Tom, The wheels are finished similar to the current economy RSR finish threads. Do a search. I did the prep work months ago but just got around to finishing them.
My Procedure: The wheels are prepped like this. First use chemical stripper to remove as much paint as possible. Then sandblast the entire wheel. I used $2.50/bag play sand in a HF pressure pot blaster. I set the pressure at about 80 psi. T his will remove the residual paint and also etch the surface of the factory annodizing. The resulting finish will look like flat aluminum with a very rough texture. The next step is to mask the center to the pattern of your choice. I think that masking these wheels was the worst part of the whole project. Next I sprayed two coats of rattle can primer and then 3 coats of satin black. Both were $5/can Rustoleum products. To finish it all off I sprayed one light coat of satin clear on top of it all. The rough texture and the clear gave a slight sheen to the aluminum finish.
The oil cooler setup was entirely DIY. No kits at my house. Its a Setrab radiator style cooler. I just found one that had the size I needed to fit snugly in the nose. Then I started cutting. Once the cooler was fitted and the lines attached I sketched the shroud on cardboard and built a metal version. Any local HVAC shop could make the shroud for a nominal fee.
Funny, I don't have any pics of the engine except when I first picked it up. Let's just say it was a bit dirty.
tcesar888 03-24-2008 07:30 PM
Jamie,
Hey, thank you very much for the come-back on how you handled these projects. As a follow-on; where did you attain the cooler and hoses? Custom too? Also, did you find your config to drop the temps dramatically?
Thanks again! SmileWavy
Tom
jpnovak 03-24-2008 07:56 PM
the oil cooler setup came from several sources. the cooler came from Hoerr Racing products (www.hrpworld.com). The hose and hose ends came from my local Aeroquip dealer. FYI, they have roll leftovers that they sell at a reduced cost/foot. You just have to dig until you find the right length. Call your local airplane mechanic to find the best location in town. The other adapter fittings came from BAT, Inc. in FL. I am using a Mocal thermostat mounted in the pass rear wheel well.
I do expect a noticeable change in temperature. The problem is that I can't give you a number. When we bought the car it was too rusty to drive hard enough to get really hot. After lots of surgery its finally ready to go. With the 2.7 oil temperature is key. My cooler is sized about 20% smaller than a Carrera Fender mounted cooler. I think I make up in airflow what I loose in capacity. Time will tell if this is true but other's have noticed the same effect.
jim72911t 03-24-2008 08:00 PM
jpnovak,
Beautiful car, and it inspires me to finally make some progress on my light ivory '72T this year.
Originally Posted by jpnovak (Post 3845467)
... I fit the new wheels and tires but they will not work. they are too large and are rubbing badly in the rear. I will try a bit more negative camber but I don't think that will solve the problem. I don't want to shave the fender lips but that is an option.
Out of curiosity, what size tires are you running in the rear? I've gone back and forth with getting a set of 4 16x7's and mounting 205/55's all around. Maybe they won't fit after all?
Jim
Jays72T 03-24-2008 09:40 PM
Well done, looks great!!!
dtw 03-25-2008 08:07 AM
I really like how it turned out. Need more pics of interior and engine bay ;). Good luck with the tire fitment issues.
jpnovak 03-25-2008 11:54 AM
Jim, I am running ES100s in a 205-55-16 size. They "should" fit according to everyone in the archives. They rub on the sidewall about 1 inch past the treadblocks. I will be increasing the rear camber and possibly shaving the fender lip.
I will try to get some pictures of the engine and interior.
jpnovak 03-31-2008 06:08 AM
It seems that nearly 3 deg neg camber in the rear will allow the tires to clear. Now I just need to roll the fronts to a wider arch.
so here are a few more pics as requested.
The engine. I have only washed the years of grime off it. I hope to clean and powder coat the fan/shroud, tin, valve covers etc...
http://forums.pelicanparts.com/uploa...1206968554.jpg
The "correct MFI pump".
http://forums.pelicanparts.com/uploa...1206968731.jpg
The sport seats redone in correct basketweave centers and perforated bolsters.
http://forums.pelicanparts.com/uploa...1206968605.jpg
My homemade basketweave door panels.
http://forums.pelicanparts.com/uploa...1206968647.jpg
Another rear shot. yes, this is a garage paint job.
http://forums.pelicanparts.com/uploa...1206968784.jpg
http://forums.pelicanparts.com/uploa...1206968800.jpg
And the car is now finished enough to wear its marque badge.
http://forums.pelicanparts.com/uploa...1206968837.jpg
