Meka's Avatar
Rear shift coupler
Is there a trick to removing the center pin from the rear shift coupler to replace the bushings? Other than a heavy duty press?
1984 Carrera
Old 03-24-2008, 06:24 AM
You can tap it out with a hammer being careful not to break one of the ears. I used a hammer and a blunt punch, supporting the coupler and only allowing enought room below to clear the pin. I laid mine on top of a vice. It actually takes more than a tap, but it might help if you spray in some PB blaster to help break away any bonding that may have occurred from dry metal on metal.
Tony G
2000 Boxster S
Old 03-24-2008, 06:28 AM
911quest's Avatar
If it won't budge take it to your local machine shop and have them press it out and reinstall it for you. Some guys have had luck tapping them out with a hammer or using a vise to press it out.
Tony Proasi
1969S
1957 VW Pickup
Old 03-24-2008, 07:48 AM
gtc gtc is offline
abides.
gtc's Avatar
I used a hammer and drift to tap out the pin, and an appropriately sized deep socket on the other side to support the bushing without resting on the coupler. It took 2 people, and was kind of a pain, but it worked out fine.
Graham
1984 Carrera Targa
Old 03-24-2008, 08:00 AM
durn for'ner
livi's Avatar
I got lazy and bought a new coupling..not that expensive.
Markus
Resident Fluffer
Carrera '85
Old 03-24-2008, 08:22 AM
rsrfan's Avatar
I used a torch. A little messy, but no chance of breakage.
JP
JP
86 930/4 tribute beasty
81 sc beach beater
‘55 Belair
‘40 Ford pickup
Old 03-24-2008, 08:39 AM
Somatic Negative Optimist
Gunter's Avatar
No heavy duty press!
Soak it in some penetrating oil.
I didn't like the hammer-method; I use my vise with various items like a socket in the back and a short drift in the front to squeeze the pin out.
The key is to prevent the ears from breaking while you force the pin out.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 03-24-2008, 08:46 AM
CT944's Avatar
I tapped mine and one of the ears cracked in half...ended up buying a new one with the bushings installed.
anyone need a coupler bushing kit and a cracked coupler??
2007 997 TT
1992 500e
Old 03-24-2008, 04:34 PM
4flyboy's Avatar
I used a heavy duty press and was very uncomfortable with the amount of force needed. It finally came out and too much force to put back. For some reason it didn't break. Maybe the soaking or spraying will help.
Scott
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 03-24-2008, 07:18 PM
