Removal of Interior Door Panels - help
I am looking for info on how to remove an interior door panel on an early car. My passenger door latch died yesterday. I have searched here and elsewhere to no avail. Any info would be appreciated.
Obligatory pic (when the latch still worked )
David 1972 911T/S MFI Survivor |
I have a pictorial guide for 74 on if that will help?
madmmac AKA Mitch 1984 Factory Turbo Look 2006 4Runner 1998 TRD Supercharged 4Runner (Sleeper) |
That would be awesome - I think!
If your car has original door pockets, then you have a different proceedure. The rear pocket is easy enough--just remove the elastic cord and unscrew the plastic hinges on the bottom. The front pocket is a little tricker. It is held on by hinges at the bottom, a screw by the front of the pocket, near the top that is easily accessable. The final holder is a 10mm nut that you must access through the hole the fold-down pocket covered. The nut is on a bolt coming from the top rim of the pocket and can be removed with a small socket or box wrench.
![]() In the photo, the nut is just behind the door panel where the chrome strip on the pocket rim meets the vinyl.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 03-24-2008 at 06:47 PM.. |
