rfuerst911sc's Avatar
simple question- oil cooler seals
I did a search but didn't find an answer, if I missed it I apologize. Anyway when installing new engine oil cooler seals do you put anything on them? Engine oil,teflon grease? Anything? Thanks
Old 03-28-2008, 01:53 PM
Mitch Leland's Avatar
I use a sticky stuff that is used in Aviation called "fuel lube". It keeps gaskets and "O" rings in place during assembly and it will allow you to remove gaskets without having to scrape them off. If the gaskets call for a Permatex type product then that is a different story.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 03-28-2008, 02:02 PM
