Chris Lovell's Avatar
Mobil1 15w50 at Costco
I've seen Mobil1 15w50 at Costco over the last 6 months or so for $30/six quarts. I think $5 a quart is decent. I suspect many of us who suffer with winters are looking for fresh oil for spring.
Just fyi.
CL
CWL
'88 Carrera Cab
Old 03-12-2008, 12:10 PM
pump_man
Send a message via MSN to pump_man
what's a quart?
Old 03-12-2008, 04:41 PM
HarryD's Avatar
Hi Chris:
Beware of the API SM grade stuff. It may not be the bargain you think.
Read me.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-12-2008, 05:36 PM
You'd better hope none of the Motor Oil Fundamentalists read this. They're trying hard to save the souls of nonbelievers by full immersion into Brad Penn and Swepco.
WIX filters and Mobil 1 15w 50 for my 911
1987 Carrera 3.2
Old 03-12-2008, 06:01 PM
dshepp806's Avatar
No API SM grade.
What are you looking at?
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-12-2008, 06:02 PM
HarryD's Avatar
Hey, your car, your choice....
Harry
2020 MB E350 4Matic
Old 03-12-2008, 06:21 PM
Okay. Right you are. SM grade. Would this be usable if I find and use a ZDDP additive? Or is this best to return?
Thanks,
CL
CWL
'88 Carrera Cab
Old 03-12-2008, 07:21 PM
laughac's Avatar
Send a message via AIM to laughac
I have purposely avoided the oil purest threads because they only seem to recommend rare oils that PCA members tend to sell out of their trunks like Amway soap.
Can someone post the short list of mainstream oils that are okay?
2000 Boxster S
2004 330ci convertible
1978 450 SLC
1924 Model T Ford touring
Fleet of Ford Buses, Sedans, SUVs and Limos
Old 03-12-2008, 07:28 PM
The Mobil One 15/50 and the Extended Performace version both have 1200 ppm of zddp as per the Mobil web site. Each of them are SM oils but do not attempt to meet the more stringent epa regulation(I believe GF-4?, from memory) limiting ZDDP to 800 ppm. I found their web site very informative esp. their Q and A section, Jerry
Old 03-12-2008, 07:34 PM
I think Billy Mays is selling pure ZDDP in pure form like Mighty Putty. No check that. I was dreaming.
Old 03-12-2008, 07:59 PM
Loose nut bhind the wheel
Billy only sells the stuff to get it out from under your fingernails. What were you thinking.
Ed
1970 911S Targa 2.7RS MFI dual plug 10.5:1
1974 260Z SCCA ITS
1998 M3
Old 03-12-2008, 08:06 PM
Mobil 1 web site is very helpful. As is the customer service phone number.
With all the back and forth about motor oils, none of the self-appointed experts have provided proof that Mobil 1's silver cap 15w50 is any less effective than the brands they are promoting.
1987 Carrera 3.2
Old 03-12-2008, 08:17 PM
I thought the problem with Mobil 1 is that the new stuff does not have enough zddp, not too much....no no I don't wanna know, don't wanna knowwww.....
Old 03-12-2008, 08:46 PM
the the is offline
Other than the exhaustive and scientifically valid oil analysis, using multiple samples, sampling and testing brand new oil, sampling and testing oil after it has been run in the engine a while, etc., you are correct. No proof at all other than that.
Old 03-12-2008, 09:14 PM
Wickd89's Avatar
I have used Mobile1 0W40 and have no leaks. Also used Mobile synthetic for my tranny oil.
Surprised that Porsche actually needed to change their recommended oil for older cars.
From now on I am trusting the Pelicans. I plan to go to Brad Penn partical synthetic next time around.
Luis "once was - Wickd89"
Carrera 3.2 - "Faster, Stronger, Better"
-- 2008 Toyota Camry SE V6 (mine)
-- 2005 Toyota Sienna (hers)
-- 1989 911 Carrera Cabriolet -SOLD
Old 03-12-2008, 09:19 PM
GothingNC's Avatar
Brad Penn is Cheaper then Mobil One.
Only cost me $3.50 per quart including delivery in NC.
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 03-13-2008, 04:44 AM
Pete000's Avatar
Who is Brad Penn and why is his oil so special ? Does he have secret ingredients?
Work to Live, don't live to work...
Old 03-13-2008, 08:06 AM
GothingNC's Avatar
It's Green so it's better
They bought out the original Kendall oil manufactuing facility in PA
http://www.bradpennracing.com/
John D.
2012 Golf TDI
Old 03-13-2008, 08:10 AM
Hey! it's not just green! it's racing oil! Kabooom!!
Old 03-13-2008, 09:37 AM
Just bought some Mobile 1 sys in those 5 Quart jugs for about $4.50/ qt. - WalMart
Here an interesting oil test http://neptune.spacebears.com/cars/stories/mobil1.html
Old 03-13-2008, 10:41 AM
