Leakdown Test
Recent leakdown test and here are my numbers:
Cyl 1 - 99%
Cyl 2 - 99%
Cyl 3 - 99%
Cyl 4 - 92%
Cyl 5 - 92%
Cyl 6 - 99%
Should I be worried about Cyl 4 & 5?
Thanks,
John
Old 03-30-2008, 03:34 PM
haycait911's Avatar
with those #'s 4 and 5 are your best cylinders! leakdown number's are usually expressed in percentage of leakage. ie:
1-1%
2-1%
3-1%
4-8%
5-8%
6-1%
as far as those two cylinders I wouldn't worry yet. drive it for a bit then re-do the test. these engines are quite variable with these things. I usually look for a trend over two or three tests before getting concerned. did you check to see where the leakage was coming from on 4 & 5?
Old 03-30-2008, 03:57 PM
Thanks.... I should have listed the numbers as:
1-1%
2-1%
3-1%
4-8%
5-8%
6-1%
Did not check where the leakage was coming from. This is the second time the leakdown test was conducted over the past couple of years. I was told that the numbers were fine and the car is running great!!! Just wanted to hear from this group.
Thanks,
John
Old 03-30-2008, 04:31 PM
dshepp806's Avatar
What were your previous #'s? And, were they done by the same shop?
Best,
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-30-2008, 04:36 PM
Numbers from the first test:
Cyl 1 - 1%
Cyl 2 - 1%
Cyl 3 - 1%
Cyl 4 - 10%
Cyl 5 - 10%
Cyl 6 - 1%
Test were conducted over a year time frame.
Thanks,
John
Old 03-30-2008, 04:43 PM
