There were two 914's made with 908 engines...one for Ferry ( with silencers and such. slightly detuned...the other for Piech closer to racing 908 HP tune, and a bit more raw.....
..but mid-engine...not an 8 hung out way past the back axle !! |
EarlyPorsche if you want a v8 so bad go buy a camaro/vette.
Even the Carrera GT/Enzo are overweight pigs (McLaren F1 did something right with CF) Alot of you guys are doing as much weight reduction as possible.... what do you think the heaviest item (other then frame) is in your car? It's time for smaller turbo motors :) There is a reason Lotus Elise/Exige are very fast track cars, and it's not cause they have 600hp All depends on what you want I guess.... |
Sorry, if Im going to pay $ for a car that has every gear PRESSED onto the mainshaft and that any sign of problem leads to replacing either the transmission or engine (hopefully under warranty), for $70K you can pick up a Nissan GTR (7:38 on the ring) which is faster than any of today's Porsche street offerings except the GT (same can be said for the Z06 for those menationing Corvette) which does in the ring in 7:36.
The Nissan GTR is a 3.8L 6cyl TT V6. This is apples to apples, if Porsche has their ***** together, they should be able to do the same with a flat 6 3.8L TT |
granted its almost 400lb heavier than the F1 (il capo di tutti capi) but there is a lot more safety equipment etc that has to be built in these days |
To note: a V8 does not have the low slung weight of the flat 8. Keeping the cylinders and heads lower makes the handling work like it does. |
I agree that today's cars are too heavy. The M3 is 3600 pounds!:eek: Who cares if it has 400 hp and a V8. It needs it to lug its massive bulk around. Same for almost all other "performance" cars, except for things like Lotus (Loti?). My car is stripped of all non-essentials and weighs 2000 pounds. It does just fine with a 2.7 liter flat 6 with 210 hp and 188 lb/ft of torque.
EarlyPorsche, I think you are alone in wanting a flat 8 in a 911. I fail to see the reason behind your beef with turbochargers, furthermore. I don't mean to be too harsh- don't take this post in the wrong way. |
These days, all high performance cars deliver essentially equivalent quantifiable performance. Some appeal to cost accountants, others to quality engineers & drivers.
I think the last thing you would want is a longer engine with more rear weight basis =
Now - a flat eight cayman - 3" more wheelbase - Now you are talking. Still though modern turbos - DI, variable vane - that's where it's going. And I too cringe at some of these "heavyweight" sports cars - the Nissan is 3900 lbs - the M3 is 3600 lbs. At least the Z06 is closer to 3000 - Keep the power - lose the weight - that's what I would do. |
I'm sure others with more engine experience can chime in as which flat-six engine solution would provide maximum low-end torque. There is always a trade-off between high rpm horsepower and low-end torque. Perhaps the 3.6 Varioram engine would be your best option. |
911 & 930's are a mind set, they are flat 6 and there is no substitute.
If you want something different go for it. I would NOT change the handling and performance of our "flat 6" cars. My2c. |
On the flip side, I remember maybe 20 years ago reading the chart about cars in the back of Road & Track - the one that is a summary of all their tests of the various cars. There was one car that was faster than any car on the list, both 0-60 and through the slalom. It was the one that was bolded on those figures - and some others too. Then at the end of that car, where they had comments, it said "a bit pricey for a 4 cylinder." I was flabbergasted. Here the car was, best of the heap, yet they criticize it. Maybe they should have said "did with 4 what others couldn't do with 6, 8 or 12." |
it seems everyone is busy justifying 6 cyl.
Just one question, tho, what great good are 8 cyl. going to bring? Why would you need 8 cyl? |
| All times are GMT -8. The time now is 02:44 PM. |
