82' Porsche 911 sc
Assistance required!!
Hi All,
I'm having issues with my -1982 Porsche 911 sc-. Car starts perfectly but the engine dies right away. I feels like if the engine was not getting any gas. I press the gas pedal with no response (it happened all of the sudden, car was running fine, went to visit some friends and when I was about to leave, it started giving issues). Once again here are the symptoms.
.Car starts no issues.
.Gas pedal does not responds
.Engine dies after a few seconds. (sometimes it stays running very weakly and
dies once I press the gas pedal).
Can anyone please give me a hand with this issue?
Thanks in advance for all your help!!
Old 03-30-2008, 09:33 PM
slodave's Avatar
How about the pop-off thingy in your airbox?
Old 03-30-2008, 09:41 PM
Capitalist and Patriot
911Freak's Avatar
Check your oil cap and make sure it is completely secured, check you fuses, vacuum lines...remember it takes 3 things for a motor to run: air-gas-spark and your symptoms seem sudden and therefore probably easily corrected...
eye ball eberything in the day light and make sure everything is connected-secured..and let us know how it goes...
Good luck!
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 03-31-2008, 12:00 AM
Designer King
Paulporsche's Avatar
You should search the forum as there is a lot of info on this type of behavior on CIS cars.
Quite often it is down to an out of spec WUR, which is causing a too lean condition on start/warmup. Another likely culprit is the AAR which is not keeping the revs high during warmup. If you get a Bentley manual, or check here for past threads, you will find how to check your control pressures w/ a gauge you can get from JC Whitney for about $60.
Other things to check are all ignition items and vacuum leaks.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 03-31-2008, 05:46 AM
UnRegistered User
billybek's Avatar
+1 pop off valve in airbox.
Bill K.
Old 03-31-2008, 06:21 AM
