Porsche Crest Handbrake handle removal
Hi, how do you remove replace a cracked handbrake handle..
Old 03-31-2008, 05:03 PM
khamul02's Avatar
I cut mine off with a box cutter and replaced it with a leather after market cover. Looks really good if you dye the inner boot. Pelican sells the aftermarket deal .
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 03-31-2008, 05:12 PM
Paul K's Avatar
Great question (I have the same problem). My handle is loose- is it supposed to slide off or is there some kind of retainer? Ajurquhart- where are you? What year of car do you have?
Paul.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 03-31-2008, 05:22 PM
Hi, i`ve a 3.2 carrera supersport ( turbo look)...i am in the Highlands of scotland...i have ordered replacement from pelican, but just thought how do i replace it...mine is cracked..
Old 03-31-2008, 05:57 PM
slodave's Avatar
I used a dremel and cut it from tip to tip. The handle will smoke like crazy though!
Old 03-31-2008, 06:20 PM
Paul K's Avatar
ajurquhart:
Okay, there are a couple of rules here. 1) Please add your location to your profile, so we know where you are, and 2) post pics of your car! Where in the Highlands are you? I used to live between Dalwhinnie and Newtonmore. As for the parking brake handle- let us know how it works out!
Cheers,
Paul.
'83 SC Coupe SOLD
Old 03-31-2008, 07:12 PM
Strathpeffer, north of inverness, i`ll put a picture in as soon as i can..
How long have you been in the US ?
Old 03-31-2008, 08:44 PM
khamul02's Avatar
I think the easiest way to deal with this problem is to use a box cutter or knife and just cut long ways down the plastic handle. Once you have a single long cut, it will just peal off.
E-brake plastic handle removal
Tom Hutchinson
Old 04-01-2008, 03:46 AM
I removed it with a heat gun, applying enough heat to soften the glue that's on the inside, but not enough to melt the plastic handle. If you don't have a heat gun you can use a hair dryer.
1986 911 Turbo
Old 04-01-2008, 04:00 AM
Carrera Cab Connoisseur
nyne11's Avatar
+1 on the Dremel or small cutoff wheel. I placed lots of rags about to catch the plastic dust and other bits. Once cut through it is very easy to remove. I replaced mine with a Billet aluminium one from http://www.betterbodiesmotorsport.com/interiors/customal/handbrake.html
and am very pleased with the result
Dave
1986 Carrera Wide Body Cabriolet
1993 Nissan 300ZX Twin Turbo (620rwhp)
2003 BMW 330Ci MSport Individual
1973 Mercedes 350 Custom Convertible
Old 04-01-2008, 05:23 AM
khamul02's Avatar
Originally Posted by nyne11 View Post
Hey mate, Your pedals are on the wrong side
Tom Hutchinson
Old 04-01-2008, 11:31 AM
Thumbs up Thanks all
Gents,
I`m going to go with the "heat" option initially, i`ll borrow the hairdrier, if that fails i`ll cut it off, then i suppose i will just glue the new one back on...
Once again thanks to all for the advice.
Old 04-01-2008, 12:42 PM
