Czar of C.R.A.P.
Help Identify Calipers
I believe these are "S" calipers but not sure of year. Need rebuild kits. I didn't see a Porsche number only the H137 and an X. The brand name is ATE. The parts breakdowns that I looked at didn't have the square portion.
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
Yes they appear to be the early alloy S calipers. Are the mounting holes at a 3.5" spacing? I think there is only one kit for all years of the alloy "S" caliper and are host has them.
Mark Jung Bend, OR MFI Werks.com |
Actually, I call those the late 'S' caliper. These were in use from at least 1974 and on the first 930. The early aluminum 'S' caliper was very similar except the 'nose' was smaller and had the appearance of the cast iron caliper. This later version has the broad nose and is probably a little stiffer. Here is the early version:
![]() Kit part # 901-351-998-00-M4 Link: http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_BRKhyd_pg4.htm#item15 you may also require new pistons: STOMSKI-SR012 on the next page.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 Last edited by djpateman; 04-01-2008 at 10:00 AM.. |
mannkar
Here's a couple pics of the 'S' calipers on my car.
